Buying Advice Wanting To Hear From Australian Chinese Tractor Owners
   / Wanting To Hear From Australian Chinese Tractor Owners #31
The two are: 504 at 50 hp and 604 at 60 hp. The 504 is about 11 years old and has the Chinese diesel in it. Issues to date are a failed bearing in the transmission output shaft to the Front WD, replaced with off the shelf bearing and seals back to back (one to hold oil in the other to keep dirt out) at parts cost $27.00 plus $200 in oil. An off the shelf ignition switch replacement at circa $10. The only other issue with the 504 is it chopped out the front tyres doing a lot of running on sealed roads when I did a lot of contract hay work. Should have put the tyres the other way around as that eases wear of tractor tyres on roads, but rubbish grip on soil as the treads clog up as soon as slippage occurs. Paint on the 504 is rubbish some stripped of with high pressure cleaning and it has faded. Paint on the 604 is good so far, no stripping , no fading.
The 604 is about 4 years old and I have had 2 clutch plates replaced. It was bought new by a guy in his 80's and I expected clutch problems because he traded as he could not handle the clutch pressure. The first time the plate was resurfaced and only riveted. For some reason the surface stripped off one side, plate resurfaced again with thicker material and then riveted and glued.
I also had the studs holding the brace arms on the font end loader break which in turn put too much strain on the bell housing studs which caused them to come loose and break out part of the bell housing casting. Not pretty but I was cleaning/extending out a 2000 cu metre dam and I guess asking it do do that which I should have used the Fiat Dozer to do but the water pump on that was un-serviceable.
I drilled the high tensile studs out for the brace, a challenge but done. The bell housing was addressed by drilling through to the inside of the casting , there is plenty of meat and tapping out the holes and replacing the studs with higher rated HT studs, the lower 2 on each side with studs 1 inch (25mm) longer and the upper 2 with similar studs 1 1/2 inches (40mm) longer as that was the additional depth of casting available for each set of studs. The upper set of studs on the RHS of the tractor had broken out between 7 mm of cast (rear stud) and 10mm for the front. I am confident the problem created by my breaking of the front studs has been overcome and I perhaps should not expect the 604 to do the job of a bulldozer!
Tightening all accessible bolts/studs on Chinese equipment seems a standard requirement which I didn't do on the 604 which I bought with 122 hrs on the clock. The dealer I purchased from told me it had been through their worksop and everything checked. Perhaps it did drive through the workshop and there was a roll-call to ensure major components were at least checked as present.
Never the less I am very happy with the 604 and it is my go-to utility tractor. Does almost everything except mow hay (need min 100 hp to run the NH 1411) and plant seed (28 run min till combine seeder) needing 100+ hp.
I run a NH 96 mower, pull a 2000litre 60ft (18metre) Silvan Boom spray, run a Bale Bandit, bale with a NH 570, rip rocks, lay poly pipe, pull 7ft grader blade, and a 16 tine scarifier with either foton. Load haybundles of hay (up to about 550kg) with the fel on the 604 and handle two 4x5 cereal hay rolls (700 to 800kg). Will not manage 3 but 3 at a time is a piece of cake with my industrial FEL.
So enjoy your new tractor that either you could afford or that left lots of $ in your pocket.
   / Wanting To Hear From Australian Chinese Tractor Owners #32
All good advice. Loctite is everybody's friend. Also routinely check the securing bolts on the loader pins. They will work loose. Even with Loctite and spring washers. I might also add that my rationale of buying a Chinese tractor (Euroleopard/Foton) for what is effectively weekend use, was, that quite apart from the cost saving, is that they are nice and heavy and that is good for even a small tractor. That's why we put water in the tyres and weights etc. Especially on hilly ground.
Also, I used to spend around half my time in China and I saw LOTS of small tractors of these types and they were seldom maintained well or within reach of a flash service vehicle with data logging capabilities. Generally a shifter, a screwdriver and a helpful crowd is what got them going if they broke down.
Fundamentally they are a good product. The Chinese formularised the 25 - around 60 horsepower tractors and most are based on (OK copied) earlier Fords, Masseys and the like and shared the designs across a multitude of manufactures. So the little understressed diesels tend to be quite similar. As a number of you have said on this forum, if you just keep an eye on things and carry out simple maintenance, they'll chug along for ever.
I have a FT404 manual which I am happy to upload if it helps anyone.
   / Wanting To Hear From Australian Chinese Tractor Owners #33
Yep tighten all bolts including those on the uprights of the loader. Usually tractors made in countries where the farm labour is the peasant class have to be simple and reliable. I know generalisations are dangerous. Still horses for courses. If I was operating a commercial quarry, I do not think I would buy a Chinese industrial FEL yet, in a few years possibly. To have a FEL that has a 1.7 cu metre bucket (water level) and lifts 3 tonnes (6600 lbs) with ease it is an absolute bonus for my small scale operation. Same sized Cat for the same price was a 15000 hour machine that was in urgent need of attention.
   / Wanting To Hear From Australian Chinese Tractor Owners #34
Hi Dave,
I imported a Dongfeng tractor from China about 18 months ago into Melbourne Aus
It is a 35HP 4wd, I purchased it with the 4 cyl European spec motor
Was a fairly simple process
I had looked at local tractors, and the tractor was available here branded Eastwind / midway sales.
If you want any additional info just ask
   / Wanting To Hear From Australian Chinese Tractor Owners #35
Hi Dave,
Was there much price differential, to the locally sourced tractors?
Were there any difficulties or delays on the Wharf or through customs?
Did it come in a container or as deck cargo, or as cargo in a hold?
When the fotons (Euroleopards) first hit the market in the West there were several operators bringing them in with wide a range of models. The range of models soon reduced and there are only a few examples of some types here, eg my 504.
Is your import the same colour as the locally sourced tractors?
Euroleopards are here as red via one importer and blue via another.
Very adventurous of you.
   / Wanting To Hear From Australian Chinese Tractor Owners #36
Hi Again
The tractor cost me $$7549, but remember I upgraded to the 4 cyl motor, synchro shuttle shift, disk brakes,Rops with canopy, exta hydraulic remotes
less than half the cost of the local product with 3 cyl motor.
As I also purchased a number of additional impliments 4 in 1 FEL TZ04D-1/5 To suit Dong Feng DF-354,LW-7 Backhoe With hydraulic Pump, HD09 Hole Digger, TL95 rotary tiller, Slasher TM140, Log Splitter, Flail Mower & Carry All
All of which case to a further $6600
I the whole lot was delivered in a 20 ft container.
Local handling in China including freight to Aus added another $2000
Colour is red, you could choose red, blue or yellow. I don't recall any limitations
I chose the Dongfeng as it has a much better reliability record than the Fotons
And you can buy the parts localy from East wind tractors, who seem to have reps in all states. though not sure about the 4 cyl motor. dut i got a kit of spares with the order, all gaskets, spare heatersa and injectors filters etc.
The delivery schedule was right on time up to receiving the documents from China they were two days late.
The tractor came in a sube cage, in knock down form, so a little assembly required, nothing a person with a spanner couldn't handle, as lond as you don't try and use the tools supplied,
You could get 8 tractors in a 20ft container.
The only problems I have had so far are with the impliments, dut all minor. I could write a book on the experience, and it would be a comedy, we still laugh about some of our experiences.
   / Wanting To Hear From Australian Chinese Tractor Owners #37
   / Wanting To Hear From Australian Chinese Tractor Owners #38
I bought my Jinma 304 as a crate tractor to save money and shipping costs to the Virgin Islands. I learned a bit putting it together and then learned more with a few otherwise easily-avoided issues that cropped up due to my ignorance of tractors in general. Still, I saved a bundle and have a solid tractor I enjoy greatly. A workhorse that has the weight/traction to get the job done, though not quickly, as the 30hp engine is about 10hp shy of what I would rather have for the size/weight of the tractor. That said, it outworks similar-sized Kubotas that a couple friends own and has has been reliable as a cheap watch - not always accurate, but always runs. (grin) I think most of the Chinese tractors fall into this category, regardless of the badge. The persistent bugaboo on my tractor has been the electrics, which I mostly sorted out by replacing the key switch and the alternator with heavier-duty, American-made units. Would I do it again? Absolutely! Even if I could afford a Kubota.
   / Wanting To Hear From Australian Chinese Tractor Owners #39
My Agrison 50 hp 2012 G3 is for sale - around 1 year old and only 55 hrs. Any offer around 20k is welcome
All the bad press they getting throughout Australia at present time seems a number of people are trying to get rid of or flog off their re-badged Agrison tractors. Best of luck Klaush.
(3) ROLLS OF 4' GALVANIZED FIELD FENCE (A54757)
(3) ROLLS OF 4'...
1982 GOOSENECK 24FT TRAILER (A52472)
1982 GOOSENECK...
BUSH HOG 1815R1 BATWING MOWER (A51247)
BUSH HOG 1815R1...
2020 Freightliner M2 106 Elgin Whirlwind Series MV Street Sweeper Truck (A55852)
2020 Freightliner...
6-NEW ALTERNATORS (A55745)
6-NEW ALTERNATORS...
