Recommendations on Trailer Manufacturers
   / Recommendations on Trailer Manufacturers #1
jacksmithers
Richmond, VA
Kubota L4740
Looking for recommendations...
I am planning to purchase a 6 ton 20 foot equipment trailer to tow my Kubota, FEL, and backhoe.
Been going back and forth on which manufacturer to choose.
Here is where I am, comparing trailers that seem to have roughly the same specs:
- Hudson: I can get a Pro series trailer with the specs I need, quoted at $5,300.
- BigTex: I can get a Big Tex trailer with similar specs for $4,600
- Holmes: I can get a Holmes trailer with similar specs for $4,450.
- Down to Earth: I can get a Down to Earth trailer with similar specs for $3,800
I've been told that the Hudsons are the best. It's hard for me to tell differences in quality by looking at these trailers, though I have noticed some things I questioned in the options besides the Hudson. I could pay the $5,300, I just want to save money if I don't need to spend it.
I don't plan to tow much initially - couple times a year, but the way I do things I could end up towing much more. Just don't have any immediate plans to do so.
Thoughts and reccomendations?
   / Recommendations on Trailer Manufacturers #2
I'm a little biased because they are built right up the road from me, but it's really hard to go wrong with a Big Tex trailer. With the amount of times you're planning to use yours yearly, I think you would enjoy it.
I have a Kearney - which is a step below Big Tex. Still built here in East Texas, but whenever I am around a Big Tex trailer, I can easily see the upgraded difference in quality with a Big Tex vs. my Kearney.
Let us know what you decide!
   / Recommendations on Trailer Manufacturers #3
I've an '07 18' HSE "5 Ton" Deluxe w/the 2' Beavertail. I got it when I bought my B7610 in Virginia Beach. It's a nice heavy duty trailer. What type axles? Ez-Lube or Never-Lube?
If your only going to use it a few times a year you might not find an advantage in spending more money.
/edit - also make sure it's deck is wide enough for what you want to carry - My Hudson is only 78" between the wheel wells. My M4700 needed 79". Other 12,000 lb trailers are 80" and 82".
   / Recommendations on Trailer Manufacturers #5
Look at wiring, paint, axles, welds, ect. Check these areas for quality and make your decision.
Chris
   / Recommendations on Trailer Manufacturers #6
   / Recommendations on Trailer Manufacturers #8
I'm VERY happy with my Hudson trailer, it's an 18' with a 4 ton capacity. My needs have changed a bit since I bought it and I want a 25' trailer now. I will stick with Hudson if I buy new when I get a bigger one, regardless of the extra cost. I personally think it's worth it over the 'value priced' trailers. You do get what you pay for.
   / Recommendations on Trailer Manufacturers #9
Big Tex are a decent trailer. Not familiar with the other three. I would be hesitant of something a thousand dollars cheaper.
   / Recommendations on Trailer Manufacturers #10
Chris
By researching and looking at trailers with the things suggested by Chris, I bought from a local Mfg- Betterbuilt in Double Springs, AL and had everything I wanted for the same price as a mass produced trailer with less features. I got sealed wiring harness, LED lights, Dexter EZ Lube axles, 100% paint, spare tire, chainbox, extra bracing, ramp assist springs, custom paint, PT deck. No shipping as I picked up at plant.
Very pleased with it.
UNUSED X-STAR ACS LOADER BOOM LIFT (A52706)
UNUSED X-STAR ACS...
E-Z-Go Workhorse Utility Cart (A55851)
E-Z-Go Workhorse...
2001 Dodge Ram 3500 4x4 Knapheide Flatbed Truck (A51692)
2001 Dodge Ram...
2005 Ford F-250 Service Truck (A55852)
2005 Ford F-250...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
RV Hitch (A50121)
RV Hitch (A50121)
