Need Help with Cluth Adjusment
   / Need Help with Cluth Adjusment #1
Qapla
Gator Country
New Holland TC40D HST 4WD FEL/BH
We have the MF 240 and had to install a clutch.
Before the new clutch we cluld not shift the gears with the tractor running. PTO worked OK.
Now, with the new clutch, the gears work just fine but we cannot turn the PTO on with the tractor running?
Any help would be appreciated.
Wow!
80 views and still no one has any info :(
   / Need Help with Cluth Adjusment #3
Does it now grind when you try to engage the pto?
   / Need Help with Cluth Adjusment #4
Good Afternoon Qapla,
It sounds to me like you have to adjust the PTO clutch, it should be in your operators manual if you have one...
On my tractor there is an access cover on the left side of the clutch housing, remove the cover and adjust three equally spaced bolts with locking nuts so that the head of the bolt gives you a .040 feeler clearance. I would think this would be spelled out in the manual...
   / Need Help with Cluth Adjusment #6
2020 Club Car Onward HP Li ION Electric Cart. (A56859)
2020 Club Car...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A56436)
2023 Unverferth...
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A58018)
2020 KENWORTH T680...
2014 Freightliner M2 106 Palfinger PK22002EH Knuckleboom Crane Truck (A55973)
2014 Freightliner...
3650 (A47477)
3650 (A47477)
2015 Freightliner Derrick Digger (A55973)
2015 Freightliner...
