Need Help with Cluth Adjusment
   / Need Help with Cluth Adjusment #1
Qapla
Gator Country
New Holland TC40D HST 4WD FEL/BH
We have the MF 240 and had to install a clutch.
Before the new clutch we cluld not shift the gears with the tractor running. PTO worked OK.
Now, with the new clutch, the gears work just fine but we cannot turn the PTO on with the tractor running?
Any help would be appreciated.
Wow!
80 views and still no one has any info :(
   / Need Help with Cluth Adjusment #3
Does it now grind when you try to engage the pto?
   / Need Help with Cluth Adjusment #4
Good Afternoon Qapla,
It sounds to me like you have to adjust the PTO clutch, it should be in your operators manual if you have one...
On my tractor there is an access cover on the left side of the clutch housing, remove the cover and adjust three equally spaced bolts with locking nuts so that the head of the bolt gives you a .040 feeler clearance. I would think this would be spelled out in the manual...
   / Need Help with Cluth Adjusment #6
2018 Ford F-350 Flatbed Truck (A55973)
2018 Ford F-350...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
2015 AMERITRAIL MANIFOLD TRAILER (A55745)
2015 AMERITRAIL...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A56435)
2020 Westfield MKX...
2015 Chevrolet Silverado 3500HD Knapheide Enclosed Service Truck (A56858)
2015 Chevrolet...
2016 JLG 3248RS Electric Scissor Lift (A56857)
2016 JLG 3248RS...
