Reverse Backhoe bucket
   / Reverse Backhoe bucket #11
If you reverse the cylinder, it will still curl when the cylinder is retracted. Doesn't matter which way the cylinder faces.
From the video above:
Bruce
exactly what i was thinking about the tilt rotator, but one could get dizzy and end up like this guy
   / Reverse Backhoe bucket #13
Just rotate the cylinder 180 degrees so the rod is towards the backhoe rather than away from it. You will need to extend the two hydraulic lines, certainly the one closest to the backhoe which is now going to be closest to the bucket. The other one should be in a similar location andyou may be able to adjust the existing line.
Orientation does not affect how much force the cylinder develops when retracting or when extending.
   / Reverse Backhoe bucket #14
What difference would that make? The cylinder action is still the same.
Terry
   / Reverse Backhoe bucket #15
Bruce
Terry
... = Why I asked. I couldnt see any easy way to uncurl the bucket with cyl extension. Thot I must be missing the point somewhere. :confused3:
larry
   / Reverse Backhoe bucket #16
Terry
It looks like you are correct. Piloon suggested that and I had not given it enough thought. To get the stronger cylinder direction while digging with the bucket backwards would take a lot more than flipping the cylinder around. You'd have to get the cylinder on the bucket side of the dipper or something which is not practical.
INSPECTION (A51573)
INSPECTION (A51573)
NEVER USED FECON 74in Deck Mulcher FDM74 (A52128)
NEVER USED FECON...
2015 Volkswagen Passat 1.8T SE Sedan (A50324)
2015 Volkswagen...
2017 Ford E450 Super Duty 20 Passenger Bus (A47384)
2017 Ford E450...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52128)
80in HD Tooth...
2022 LEGUAN 190 SPIDER LIFT (A51242)
2022 LEGUAN 190...
