Help me find my tig problem
   / Help me find my tig problem #41
   / Help me find my tig problem #42
Technically you need to have grade T hose, and you'll need a propane tip. But I'll bet you have a propane tank around some where. Propane takes just a little longer on the preheat, but it cuts very nice.
Propane & Oxygen Torch Cutting Instructional Video - YouTube
How about heating tips? Dows the oxy-propane mix properly with a standard rosebud or is that special as well? (Sorry to highjack the thread by the way folks, my apologies)
Sent from my LGL35G using TractorByNet
   / Help me find my tig problem #43
How about heating tips? Does the oxy-propane mix properly with a standard rosebud or is that special as well? (Sorry to highjack the thread by the way folks, my apologies)
   / Help me find my tig problem #44
Seems as we all hijack threads here.:laughing:
No for propane you need a propane rose bud. Personally I don't like propane for heat shrinking items, but for general heating it works fine. Now a days the majority of my heat shrinking is done with a cutting tip. Back in the day when I had to do beams I'd use a couple #12 rose buds, but those days are long gone.
First picture is a propane, and acetylene rose bud side by side, third picture is the propane rose bud, and third is an acetylene rose bud.
   / Help me find my tig problem #46
Looks like I'll be picking up some new hose and a couple tips...I've already got a 100# propane for my gas forge...a tee with a shutoff from that in the shop will work well I think. For outside/offsite I'll stick to the acetylene though, that propane's a b**** to move around. Thanks for the kick in the pants Shield Arc!!!
   / Help me find my tig problem #47
"that propane's a b**** to move around."
Keep in mind, that even a size 5 acetylene is barely adequate for ANY rosebud, if you stick to safe withdrawal rates -
I have 4 of the 100# propane tanks, a couple of "bigfoot" hand trucks, a "K" size Oxy and size 5 acetylene on a big wheeled cart - BOTH O/A tanks on the cart are about the same difficulty in moving as ONE propane.
If you add a large Oxy tank to "keep up with" that size propane tank, you'll be even heavier than the largest O/A rig.
Use a smaller Acetylene tank at your own risk -
Fuel your safety knowledge - Safety Tech Cell - TheFabricator.com
I've mentioned my own "personal near death experience" here before, just tryin' to keep others from "having better luck" at success... Steve
   / Help me find my tig problem #48
I don't use a rosebud at all with my 75 cu. Acetylene...and I have to keep it limited to the small welding tips. Most of my heating is done with a cutting tip, as i rarely heat anything larger than a bolt, and the cutting tip pinpoints those pretty well. When bending, I'm usually using small stock as well, and for larger pieces, i'll pass them through the gas forge. I'm pretty aware of the withdrawal rate...I wouldn't want to be on the business end of an accident with that stuff
   / Help me find my tig problem #49
Glad you're aware, I feel it's better to mention things like that when they're NOT needed, than to NOT and have someone get hurt or worse - your question, "Does the oxy-propane mix properly with a standard rosebud ?" made me think it might be necessary.
By your later comments, my advice would be to go back and NOT read my previous post :D ... Steve
   / Help me find my tig problem #50
Unless you get a newer inverter based AC/DC TIG welder, you'll never find a 3 phase AC welder. Even the Lincoln AC 1200 for sub arc welding is single phase.
Where I work we have not had any problems getting Helium. We still sell a lot for balloons. It is still ungodly expensive though. It is in relatively short supply and the best reason I have heard why it is so hard to get is because the bigger gas suppliers like Praxair, Air Gas, Air Liquide, Linde, etc. all have contracts to supply it to medical facilities for cooling MRI machines. Liquid Helium(-452 F) is colder than liquid Nitrogen. These medical contracts have a stipulation that if the gas supplier can't supply helium when required, they pay huge late fee's, not unlike large construction projects. The big players keep it in stock for their medical customers to avoid huge late fees. I work at an independent supplier that is part of a large co-op of welding suppliers.
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2017 FREIGHTLINER...
Westerndorf 10' Box Blade (A59814)
Westerndorf 10'...
2006 Chevrolet Express 3500 Cargo Van (A59230)
2006 Chevrolet...
2016 ISUZU NPRXD 14' BOX TRUCK (A60430)
2016 ISUZU NPRXD...
2014 International Maxxforce DT (A53317)
2014 International...
2020 CATERPILLAR 242D3 SKID STEER (A60429)
2020 CATERPILLAR...
