It's a question on how well they work. Looking for fast return and splitting power. All I see in brochures is "depends on tractor". Anyone use this set up or recommend a separate splitter instead? Thanks mark
I have both a tractor powered and a stand alone splitter. I've run the tractor mounted splitter on a Kubota L39, which has very capable hydraulic flow. Even then, I have to rev the engine higher than I want to get the same speed I get out of the stand alone. I kinda hate to run a 40 hp engine at 2200 rpm to split wood... I prefer the stand alone.
That is the way I feel. Most any size tractor will be overkill in hp and fuel use, but still not have the gpm flow/speed of a stand alone splitter.
The L39 is about 15gpm, which is good flow for a tractor, but still not great for running a splitter... and you only get the full flow at max RPM. At 2200 rpm, you're probably only getting 3/4 - 2/3's of that flow, and 10-11 GPM is not going to run a splitter very fast.millstreaminn said:I've run the tractor mounted splitter on a Kubota L39, which has very capable hydraulic flow.
I know that this sure beats a splitting maul or a sledge and wedges.
