3 pt hitch log splitter on 3940 hst
   / 3 pt hitch log splitter on 3940 hst #11
That is the way I feel. Most any size tractor will be overkill in hp and fuel use, but still not have the gpm flow/speed of a stand alone splitter.
If you are using the tractors hydraulics, that's true. But if you use the tractor to power a PTO driven pump you can get 20 GPM @ 2000+ PSI.
millstreaminn said:
I've run the tractor mounted splitter on a Kubota L39, which has very capable hydraulic flow.
The L39 is about 15gpm, which is good flow for a tractor, but still not great for running a splitter... and you only get the full flow at max RPM. At 2200 rpm, you're probably only getting 3/4 - 2/3's of that flow, and 10-11 GPM is not going to run a splitter very fast.
   / 3 pt hitch log splitter on 3940 hst #12
I have a Ramsplitter that I am happy with for my uses. I connect mine to the loader ports.
I have the 12T version with the 3.5" cylinder. It is sized better for my tractor. I run the tractor ~1900RPMS, and can split everything I want to. My wood is mostly maple, cherry, white oak, various others. The average round is 18" diameter. It is fast enough for me working by myself.
I burn about 3 cords a year in the house, and 1.5 through camping and outdoor fires.
   / 3 pt hitch log splitter on 3940 hst #13
I have a split-fire two way splitter on an L4400. I run at about 1500 rpm and have no trouble splitting oak wood. With the two way splitting it is as fast as my wife and I want to work. The split-fire is a very well made piece of equipment. As far as not being able to use the loader to move split wood I find it much handier to throw it into my old wood hauling spreader. The loader just doesn't hold enough wood. However I am splitting my wood out in the woods and then hauling it up to my woodshed. A lot less trips by using the trailer.
   / 3 pt hitch log splitter on 3940 hst #14
Running the PTO powered splitter at 1800 rpm is a bit slow on the cycle time but my matches *my* pace :D
   / 3 pt hitch log splitter on 3940 hst #15
I run a Speeco 3pt splitter on my L4610 off of the rear remotes. I run the tractor at about 1500 rpms. The only time the tractor grunted was splitting a 3' round Ash crotch piece. Is it fast? No, but it will outwork me and a faster splitter would be a waste. I only work at a slow speed. 30 to 40 years ago it may not have been fast enough. I do not have another engine to maintain which is fine by me.
A plus for my splitter is I can raise it and use the tractor to pull a large log into a better cutting site, then use the forks to raise the log to cut into lengths. Then I back the tractor up to the cut wood and start splitting. The RTV is the wood hauler, we back up close to the splitter for ease of loading. This works for me, whatever works for you. I know that this sure beats a splitting maul or a sledge and wedges.
   / 3 pt hitch log splitter on 3940 hst #16
On a gas powered splitter you can always run it off of tractor hydraulics if the gas engine konks out. A little re-piping is all.
   / 3 pt hitch log splitter on 3940 hst #17
^^^ Yes! I am so glad I bought a splitter! Years ago, I used to split by hand. How dumb, LOL!
   / 3 pt hitch log splitter on 3940 hst #18
TractorData.com list the L3940 hydraulic flow at 9.8 GPM. That is same as my Case DX45 and I run a 3 point splitter with a 3.5 inch cylinder. It has split all the maple, oak and currently some black walnut I have thrown at it without problems. It goes fast enough for me as I mostly work alone. I only split a few face cord a year so I prefer using the tractor than having another engine to maintain. Also, my Kelley Co. splitter, a lucky Craigslist find for $350, is fairly compact and does not take up as much room to store as a self contained one.
I would not recommend a splitter with a cylinder over 3.5 inch as you may be disappointed in the speed. Relief pressure on my Case is 2500 psi. A quick search online showed the L3940 relief pressure at 2490 psi, essentially the same as mine.
I thought I had a better picture, but all I could find was a poor cell phone picture of it on my L39.
   / 3 pt hitch log splitter on 3940 hst #19
I haven't seen much discussion of the quantity of wood you want to split. If you only split 2-3 cords per year for a decorative fireplace, then a 3PH splitter is a good choice: low cost, very functional, low maintenance, easily stored when not in use. If you are heating your house with wood and burn 4-8 cords per year, you need a serious stand-alone splitter because your time splitting and stacking is going to be significant. Those of us who have fire places for ambiance certainly don't need to spend $2k or more on a spiffy stand-alone, but if you heat with wood and spend lots of time splitting, then you need a splitter that works quickly and efficiently without wearing out your high-dollar tractor investment.
   / 3 pt hitch log splitter on 3940 hst #20
Have 3ph splitter from Northern Tool on L4610 that I like. Run about 1200- 1400 rpm when splitting firewood.
Rotadairon RD145 Pull-Behind Rotary Tiller Tractor Attachment (A59228)
Rotadairon RD145...
1992 Norris Long Basket Trailer (A55973)
1992 Norris Long...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
2022 Polaris Ranger 900XP 4x4 Utility Cart (A55853)
2022 Polaris...
More info coming soon! (A56859)
More info coming...
John Deere Z994R (A60462)
John Deere Z994R...
