1997 F150 transmission issue
   / 1997 F150 transmission issue #31
Fixing the F-150's trans is going to be around $3,000. If you would fix it I recommend you only get a trans from the dealer because they will back up their trans. If you have any problems with it you take it in and they will fix it. If you take the $3k the trans will cost plus what you can get for the F-150 as it sits you will be hallways or more there on the price of the Chevy.
I am not a big Chevy fan but I think I would go with the Chevy. The price sounds pretty good to me. If it has been well maintained it should run along time. I would do a transfer case pump upgrade to it. These trucks have a anti rattle clip that breaks and put a hole in the transfer case and the fluid leaks out. Most of the time you don't know it til it's to late. GasTruck
A Jasper or quality trans will also carry a warranty.
Chris
   / 1997 F150 transmission issue #34
You know what you have now. Do you really want to start over with another used truck?
Fix what you have.
   / 1997 F150 transmission issue #35
Fix what you have.
Agreed.
Chris
I finally got some codes. P0122 low tps circuit input and P0401 egr insufficient flow. Would the tps cause these issues? I replaced it in 2009, truck would not downshift.
Fix what you have.
Exactly what I decided to do.
   / 1997 F150 transmission issue #38
Based on the tps's purpose, I would think it certainly could..Not an expert on the subject, but false messages are being sent and that can cause all kinds of odd behaviors...How much does one cost for your truck?..If not brutal, I'd just try it.
   / 1997 F150 transmission issue #39
These are 2 seperate issues.
Do you have a code reader or a scan tool?
   / 1997 F150 transmission issue #40
The 401 is almost certainly a PFE sensor.
The 122 will need to be checked.
2018 Ford Explorer AWD SUV (A55853)
2018 Ford Explorer...
2005 TerraGator 8104 (A55302)
2005 TerraGator...
2010 Kubota ZD326 60in Zero Turn Mower (A55851)
2010 Kubota ZD326...
WB 17" PIN ON EXCAVATOR BUCKET (A52707)
WB 17" PIN ON...
2017 Bobcat T770 Compact Track Loader (A55314)
2017 Bobcat T770...
2017 COTTRELL TRAILER (A55788)
2017 COTTRELL...
