3 point hitch on GC2300/GC2310 won't go down - any ideas?
   / 3 point hitch on GC2300/GC2310 won't go down - any ideas? #1
FredWalter
Southwestern Ontario, Canada
John Deere 5300, Gravely 8163G, BCS735, etc
I have a GC2310 that is stored outside.
This summer it hasn't seen much use.
I just got it running this past weekend (after replacing the ignition switch) so I could use it to move a bunch of stuff before everything gets covered in snow.
When I use the control to lift the 3 point hitch, it goes up.
When I use the control to drop the 3 point hitch, nothing happens. It doesn't matter how much weight I put on it, it stays up.
I discovered this problem after dark, when I went to put a carryall on the back of the tractor, and I was pressed for time, so I didn't get a good look at the linkages. (And I live in the city where I work during the week, so I'm not able to check out the tractor during the week.)
Anyone else have this problem? Any ideas?
   / 3 point hitch on GC2300/GC2310 won't go down - any ideas? #2
If the arms are properly hooked up so they don't bind, and the linkage on the 3pt control lever is properly connected, the 3 pt. down function is is controlled by only the drop speed knob below the seat, and gravity.
I don't know what else it could be.
   / 3 point hitch on GC2300/GC2310 won't go down - any ideas? #3
If the arms are properly hooked up so they don't bind, and the linkage on the 3pt control lever is properly connected, the 3 pt. down function is is controlled by only the drop speed knob below the seat, and gravity. I don't know what else it could be.
Ray did not mention that if that knob is turned all the way clockwise it will not come down. It locks it in the up position. You might try messing with that knob opening it up al of the way. Could maybe be a small obstruction there.
   / 3 point hitch on GC2300/GC2310 won't go down - any ideas? #4
people often accidentally move that knob with their feet getting on and off the tractor. Don't ask me how I know.
   / 3 point hitch on GC2300/GC2310 won't go down - any ideas? #5
Well me getting old and senile, I have locked mine and forgot what I did haha. You get some good rain over there this morning? Tomorrow is suppose to be lots of it.
   / 3 point hitch on GC2300/GC2310 won't go down - any ideas? #6
Rained some.. not sure how much.
   / 3 point hitch on GC2300/GC2310 won't go down - any ideas? #7
Fred, you did say your kids like to play on your tractor, so they may have turned the knob on you.;)
That's what I'm hoping has happened. But I won't be able to check until this weekend.
   / 3 point hitch on GC2300/GC2310 won't go down - any ideas? #9
Thanks, I Guess I needed to be more specific.
(2) UNUSED 7000# DROP AXLES W/ BRAKES (A51247)
(2) UNUSED 7000#...
UNUSED RAYTREE RMLS18T WOOD SPLITTER (A51248)
UNUSED RAYTREE...
UNUSED AGT LRT23 STAND ON SKID STEER (A51247)
UNUSED AGT LRT23...
2015 CHEVROLET SILVERADO CREW CAB TRUCK (A51406)
2015 CHEVROLET...
Red Iron Oxide in Trace Mineral Supplements for Cattle
Red Iron Oxide in...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
