Rotella T6 vs Premium Blue.
   / Rotella T6 vs Premium Blue.
I prefer the Premium Blue extreme or the T6 over the Premium Blue heavy duty. I'll spend a little more to run a full synthetic oil because of the cold climate. I'm currently running T6 simply because it's easy to get.
Now that we have a TSC locally, I run Premium Blue. Just wondered if T6 being a universal formula (gas/diesel) if it weakened the formula any!!
   / Rotella T6 vs Premium Blue. #12
Hi Will,
While the Marketeers (Mouseketeers ?) at Valvoline are not pushing the Extreme as a "Fleet" oil, it seems to have an SM rating, so it's not really much different than T6 in that sense.
If you want to know about specific additive levels check the Virgin Oil Analysis section on Bob is the Oil guy.com , esp. if the oil company is not releasing that info directly. And, the BITOGers pay to run their own tests anyway - "Show Me !".
Valvoline seems tighter with Cummins than Shell, but that may just be a reflection of a domestic business relationship more so than absolute performance.
As long as the Cummins oil spec is met, IMO you'd be fine with either, when changed at the factory intervals.
Rgds, D.
Valvoline.com > Products > Motor Oil > Diesel Motor Oil > Valvoline Premium Blueï½® Extreme Diesel Engine Oil
Valvoline逞エ Premium Blue Extreme Engine Oil is endorsed by Cummins Engine Company and is approved against the CES 20081 specification. The product meets, and is approved against, Mack EO-O Premium Plus, Volvo VDS-4, Detroit Diesel 93K218, and MB-approval 228.31. In addition, the product meets API CJ-4/SM and older category, Caterpillar ECF-3/2/1a, Renault RLD-3, ACEA E9-08/E7-08 and Perkins/Wilson engine requirements. It also meets the engine test performance requirements of MTU Type I/II, MAN 3275, JASO DH-2, and Global DHD-1 specifications. Premium Blue Extreme provides excellent performance in mixed fleet gasoline engines, pickup and delivery, city fleet, long haul over-the-road, and off-highway applications.
   / Rotella T6 vs Premium Blue. #13
Down here the local TSC only sells Premium Blue HD, not the synthetic PB Extreme. The price is the same as Rotella T Tripple. It could be just me but I like the synthetics for the dead of winter starting in high compression diesels.
I like running them year round. Just realized i forgot the extreme.
   / Rotella T6 vs Premium Blue. #15
Thanks Chris!!
Do you have any diesel trucks running Premium Blue 5W40 year round?
Looking at a Ram Cummins for my next truck!!
my 04 f250 6.0psd, my 99 f350 7.3psd, and my 99 f450 7.3psd run valvoline premium blue full syn 5w40 year round.
the 450 had been on amsoil it's entire life when i got it, and I swapped it over to t he valvoline.
.. so it has run full syn since just after rolling off the line. I guess it's 'shipping oil' was dino..
the 350 has been on it since i owned it.. i guess 4 ys?? now No issues... no leaks.. etc.
the 250 had been on the motorcraft psd 15w40 it's entire life from new, and i swapped it over to the blue about 2ys ago. While probably not related i had been having a turbo underboost error pop up now and then and within 2 weeks of the syn oil switch it has never done it again. coincidence? maybee.. maybee not.
I plan on keeping all 3 on it as long as it is out and i can afford it. :)
my 04 f250 6.0psd, my 99 f350 7.3psd, and my 99 f450 7.3psd run valvoline premium blue full syn 5w40 year round. the 450 had been on amsoil it's entire life when i got it, and I swapped it over to t he valvoline. .. so it has run full syn since just after rolling off the line. I guess it's 'shipping oil' was dino.. the 350 has been on it since i owned it.. i guess 4 ys?? now No issues... no leaks.. etc. the 250 had been on the motorcraft psd 15w40 it's entire life from new, and i swapped it over to the blue about 2ys ago. While probably not related i had been having a turbo underboost error pop up now and then and within 2 weeks of the syn oil switch it has never done it again. coincidence? maybee.. maybee not. I plan on keeping all 3 on it as long as it is out and i can afford it. :)
Thanks Chris! Our MF has spent mist its life on syn 5w40, now that we have a TDC close by, will stock with premium blue syn!!
Will be getting a new Ram Cummins down the road, premium blue syn for it too!!
   / Rotella T6 vs Premium Blue. #17
cummins specs are displyed prominently ont he blue syn add materials.. so they must be happy with each other..
   / Rotella T6 vs Premium Blue. #18
Can't really go wrong with either.
T6 is good stuff. It's built a solid reputation over on BITOG for good reason.
   / Rotella T6 vs Premium Blue. #19
I don't think you can go wrong with either of the 2 synthetics mentioned. T6 performed well for me in my cummins. I'm sure that prem. blue syn. would have performed just as well
   / Rotella T6 vs Premium Blue. #20
There are 2 oils labeled Premium Blue. the first is a dino oil 15w-40 labeled as Premium Blue. the second is Premium Blue EXTREME and is a synthetic 5w-40. the Premium Blue Extreme is comparable to the Rotella T6, not the Premium Blue.
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A51692)
2012 Crane Carrier...
1972 Baker 30ft Pole S/A Towable Trailer (A51694)
1972 Baker 30ft...
BANDIT ZT1844 RUBBER TRACK STUMP GRINDER (A50458)
BANDIT ZT1844...
2019 FREIGHTLINER M2 106 REFRIGERATED TRUCK (A52706)
2019 FREIGHTLINER...
2022 Allmand Maxi-Lite II 20kW Towable Light Tower (A52377)
2022 Allmand...
PALLET OF MILITARY STRAPS (A54757)
PALLET OF MILITARY...
