Front-end-loader backhoe unit - HOW can I get a bush hog cutter attachment on it?
   / Front-end-loader backhoe unit - HOW can I get a bush hog cutter attachment on it? #1
fandelem
jackson, ms
n/a
Hi!
I have decided that a front-end loader/backhoe combo machine (like a JD 420E) is what I need to do 80% of my tasks. But 20% is grass cutting. There has got to be some attachment I can hook up to the front end loader to cut grass! Please suggest.
   / Front-end-loader backhoe unit - HOW can I get a bush hog cutter attachment on it? #2
A SSQA hydraulically powered rotary cutter would get the job done if you had the hydraulic flow for it.
Skid Steer Brush Cutter
   / Front-end-loader backhoe unit - HOW can I get a bush hog cutter attachment on it? #4
Honestly most of the backhoe units go on and off with very little effort. I don't consider it a hindrance to change back and forth. First couple times are a bit nerve-racking, but after doing it 2 or 3 times it's as easy as any other implement change.
   / Front-end-loader backhoe unit - HOW can I get a bush hog cutter attachment on it? #5
I believe he's talking about a rubber tired hoe/TLB/combination. For the price of retro fitting aux hydro and a hydro powered cutter you could buy a used, dedicated bush hogging tractor and bush hog. Taking the hoe off would be a day long job, plus no QC on hoe hoses. Then he would need to get 3 pt arms and set up and Still no PTO to run it.
ok, so like a 30hp tractor / bubshhog is the way to go it sounds like.
what is the best tractor for a 1800 lb heavy duty bush hog attachment?
   / Front-end-loader backhoe unit - HOW can I get a bush hog cutter attachment on it? #7
Your two posts indicate your tractor experience is limited. That is OK, we are here to help.
The Deere 420 was last produced in 1958. With a Backhoe, it would be too heavy to operate on turf grass. I doubt 1958 backhoes are easy on/off.
Contemporary 30-horsepower tractors weigh 1,800 - 3,300 pounds. An 1,800 pound Rotary Cutter is too heavy for any tractor in this weight range.
A contemporary 30-horsepower tractor can handle a 60" wide standard duty Rotary Cutter, which weigh 600 pounds and will max cut 1-1/4" diameter brush and saplings. In my experience this is ample. For larger stuff, use a saw.
What are the tasks you wish to accomplish with the tractor?
What is your soil? Will you be operating only on flat land or are hills a consideration?
What are your requirements for a Backhoe, in particular? For limited digging a clamp on FEL Bucket Spade may suffice, leaving the three point hitch open for implements.
What is your budget? A new 30-horsepower tractor/loader (1,800 pounds) WITHOUT Backhoe is $17,000 with tax.
There is nothing wrong with a used, well maintained tractor with an industry standard three point hitch.
   / Front-end-loader backhoe unit - HOW can I get a bush hog cutter attachment on it? #8
No, JD-420E is a 15,000# construction back hoe.
   / Front-end-loader backhoe unit - HOW can I get a bush hog cutter attachment on it? #9
TractorData.com failed me this time.
Hmmmmm…..Good to know Deere nomenclature can be as confusing as Kubota nomenclature.
   / Front-end-loader backhoe unit - HOW can I get a bush hog cutter attachment on it? #10
If you need the TLB, I would consider a MF35/135 and bush hog for mowing. A hydraulic brush cutter will be $5k+, still need something rigged to attach to front, and need auxiliary high flow hydraulics at loader
2018 Komatsu GD655-6 Motor Grader, S/N 60403, PIN# KMTGD032PJA060403, Turbo Diesel Engine, 14' (A59076)
2018 Komatsu...
2013 John Deere 5075E (A57148)
2013 John Deere...
2013 Volkwagen Tiguan SUV (A56859)
2013 Volkwagen...
2019 MQ POWER WHISPERWATT DCA-25 GENERATOR (A58214)
2019 MQ POWER...
Vivohome Single Stage Vacuum Pump, Model VB150, 1/3 HP, 110 Volt, Vivohome Gage Set (A59076)
Vivohome Single...
John Deere 6110M (A53317)
John Deere 6110M...
