Front-end-loader backhoe unit - HOW can I get a bush hog cutter attachment on it?
   / Front-end-loader backhoe unit - HOW can I get a bush hog cutter attachment on it? #1
fandelem
jackson, ms
n/a
Hi!
I have decided that a front-end loader/backhoe combo machine (like a JD 420E) is what I need to do 80% of my tasks. But 20% is grass cutting. There has got to be some attachment I can hook up to the front end loader to cut grass! Please suggest.
   / Front-end-loader backhoe unit - HOW can I get a bush hog cutter attachment on it? #2
A SSQA hydraulically powered rotary cutter would get the job done if you had the hydraulic flow for it.
Skid Steer Brush Cutter
   / Front-end-loader backhoe unit - HOW can I get a bush hog cutter attachment on it? #4
Honestly most of the backhoe units go on and off with very little effort. I don't consider it a hindrance to change back and forth. First couple times are a bit nerve-racking, but after doing it 2 or 3 times it's as easy as any other implement change.
   / Front-end-loader backhoe unit - HOW can I get a bush hog cutter attachment on it? #5
I believe he's talking about a rubber tired hoe/TLB/combination. For the price of retro fitting aux hydro and a hydro powered cutter you could buy a used, dedicated bush hogging tractor and bush hog. Taking the hoe off would be a day long job, plus no QC on hoe hoses. Then he would need to get 3 pt arms and set up and Still no PTO to run it.
ok, so like a 30hp tractor / bubshhog is the way to go it sounds like.
what is the best tractor for a 1800 lb heavy duty bush hog attachment?
   / Front-end-loader backhoe unit - HOW can I get a bush hog cutter attachment on it? #7
Your two posts indicate your tractor experience is limited. That is OK, we are here to help.
The Deere 420 was last produced in 1958. With a Backhoe, it would be too heavy to operate on turf grass. I doubt 1958 backhoes are easy on/off.
Contemporary 30-horsepower tractors weigh 1,800 - 3,300 pounds. An 1,800 pound Rotary Cutter is too heavy for any tractor in this weight range.
A contemporary 30-horsepower tractor can handle a 60" wide standard duty Rotary Cutter, which weigh 600 pounds and will max cut 1-1/4" diameter brush and saplings. In my experience this is ample. For larger stuff, use a saw.
What are the tasks you wish to accomplish with the tractor?
What is your soil? Will you be operating only on flat land or are hills a consideration?
What are your requirements for a Backhoe, in particular? For limited digging a clamp on FEL Bucket Spade may suffice, leaving the three point hitch open for implements.
What is your budget? A new 30-horsepower tractor/loader (1,800 pounds) WITHOUT Backhoe is $17,000 with tax.
There is nothing wrong with a used, well maintained tractor with an industry standard three point hitch.
   / Front-end-loader backhoe unit - HOW can I get a bush hog cutter attachment on it? #8
No, JD-420E is a 15,000# construction back hoe.
   / Front-end-loader backhoe unit - HOW can I get a bush hog cutter attachment on it? #9
TractorData.com failed me this time.
Hmmmmm…..Good to know Deere nomenclature can be as confusing as Kubota nomenclature.
   / Front-end-loader backhoe unit - HOW can I get a bush hog cutter attachment on it? #10
If you need the TLB, I would consider a MF35/135 and bush hog for mowing. A hydraulic brush cutter will be $5k+, still need something rigged to attach to front, and need auxiliary high flow hydraulics at loader
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
1994 Stock Trailer (A57148)
1994 Stock Trailer...
Giyi Mini 44" Flat Ripper (A57149)
Giyi Mini 44" Flat...
UNUSED FUTURE TR47 FORKLIFT TELESCOPIC BOOM (A58376)
UNUSED FUTURE TR47...
SCREENER (A58216)
SCREENER (A58216)
2023 BOBCAT T770 SKID STEER (A52709)
2023 BOBCAT T770...
