Peerless Boiler Parts
   / Peerless Boiler Parts #11
Of course it's way colder where you are than where I am. Here, we insulate the vertical vent with a fabricated sheet metal box. This box is insulated inside, and covers the entire outside exposed vertical section of the vent . Sounds like your vent pipe (or a part of it) serves as a combustion air pipe and exhaust pipe. Don't see a lot of boilers down here. Your boiler may not be vented in a way that condensation can run down the vent pipe and get into the exhaust motor/squirrel cage
Thanks.
I should post a pic tomorrow.
There is a rectangular sheet metal box about 6" by 6" by 16" that is installed through the wall. The 3" exhaust goes through the center of the box (lengthwise) and there is an air intake screen on the outer end of the box where it is outside. The intake air in the box is pulled through a ~4" pipe (connected to the bottom of the box inside the garage wall) to the burner on one side of the boiler, the exhaust goes out the other side of the boiler.
It's a similar set up as a through the wall direct vent gas heater. The air intake isolates the warm exhaust pipe from the wall.
UNUSED CFG INDUSTRIAL QK20R EXCAVATOR (A51247)
UNUSED CFG...
RYOBI 40V BRUSHLESS ELECTRIC 20" PUSH MOWER (A51248)
RYOBI 40V...
ECHO PB-2520 GAS HAND HELD BLOWER (A51248)
ECHO PB-2520 GAS...
2023 John Deere HD50F Draper Head (A53342)
2023 John Deere...
2025 CFG Industrial STSD10 (A50123)
2025 CFG...
2009 Lee-Boy 8510HD Conveyer Feed paver (A53472)
2009 Lee-Boy...
