wr long or ??? for brush & logs?
   / wr long or ??? for brush & logs? #141
lwm, I know you considered the Monster Grapple, now it sounds like you should have got it.
51" opening.
400x452xMRG.JPG.pagespeed.ic.24IcWkPDdY.jpg P5240009.JPG P5240010.JPG P5240017.JPG
I am posting this to help newbies make a decision. The grapple is heavy, so it needs to be a big tractor. :thumbsup:
   / wr long or ??? for brush & logs? #142
51" opening.
View attachment 345738 View attachment 345739 View attachment 345740 View attachment 345741
No reason that exact grapple design couldn't be built in 48"-60" width with a single lid using 3/8" mild steel. That would sure cut the weight and cost.
   / wr long or ??? for brush & logs? #143
Yep, I posted that drawing and mentioned raising the pivots on one of the EA threads, but got no response from Travis.
   / wr long or ??? for brush & logs? #144
mine measures about 58-60," depending whether you go inside to inside or outside to outside i have a pic i will upload when i get to the other computer
   / wr long or ??? for brush & logs? #145
here are some pictures
and the biggest log i have picked up, i need my *** in the tractor to pick it up
Hey Terry,
have you ever wished you had two rams controlling two different top claws to grab uneven stuff?
   / wr long or ??? for brush & logs? #147
so far no, i can see where it would be a benefit and a hindrance.
   / wr long or ??? for brush & logs? #149
I know the benefit, what is the hindrance?
i use the grapple to reach into a pile and pull out one log, one something and my thinking is if you can get one half of the grapple to loosely grab it and the other side might knock it out. i got nothing at first i thought LWM was talking about a regular grapple and there aren't very good for raking, then i remembered yours that is a rake with two halves.
   / wr long or ??? for brush & logs? #150
Extra cost, extra weight, limited visibility, only rare instances where two lids are helpful and virtually none where they are necessary.
1 Bridgestone 255/70R 22.5 and 1 Toyo M-872 12R 22.5 Tires (A51573)
1 Bridgestone...
LOAD OUT INFORMATION LOT NUMBER 4 (A53084)
LOAD OUT...
2025 Star EV Capella Electric Low speed Golf Cart (A51694)
2025 Star EV...
2012 PETERBILT 587 SLEEPER (A52577)
2012 PETERBILT 587...
LOOK! (A53342)
LOOK! (A53342)
2016 Ford F-450 Crew Cab Knapheide Service Truck (A52377)
2016 Ford F-450...
