Mowing removeal of stored 1000 pto shaft to replace 540.
   / removeal of stored 1000 pto shaft to replace 540. #2
Sounds great. Hope you enjoy.
   / removeal of stored 1000 pto shaft to replace 540. #3
:confused:
   / removeal of stored 1000 pto shaft to replace 540. #4
Me to
   / removeal of stored 1000 pto shaft to replace 540. #5
see above .
Guess there is room for assumptions? To get the 1000 rpm shaft out you need to remove a large inside snap ring IIRC. I may be wrong but thinking back about forty years.
Try being a little more explicit, complete sentences may yield better responses.
   / removeal of stored 1000 pto shaft to replace 540. #6
I'm with Gator.
   / removeal of stored 1000 pto shaft to replace 540. #7
Ditto what jenkinsph stated. Remove snap ring(parts key #1) pull each shaft and interchange locations. If you'll point nose of tractor down in a ditch you'll loose less hyd oil. Also sometimes 1000 rpm shaft needs to be pulled,turned and reinstalled to get the drive splines of shaft & drive gear to line up.
   / removeal of stored 1000 pto shaft to replace 540. #8
Odd thing is that OP's profile says that he's a tractor dealer owner. If that's correct, I'd think he'd ask one of the mechanics.
   / removeal of stored 1000 pto shaft to replace 540. #9
I must kinda daft but what is being asked??
   / removeal of stored 1000 pto shaft to replace 540. #10
So if the OP is a tractor dealer why would you think his mechanic/technician would know how to interchange 540/1000 rpm pto stub shafts on a JD 4020 tractor??
VOLVO L45G WHEEL LOADER (A51242)
VOLVO L45G WHEEL...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A51039)
Kubota 24in Quick...
2014 KENWORTH T800 SLEEPER CAB (A50854)
2014 KENWORTH T800...
New Holland TS6. 120 Tractor (A50322)
New Holland TS6...
2004 Dodge Ram 1500 SLT Crew Cab Pickup Truck (A50323)
2004 Dodge Ram...
2005 Sterling Acterra Tender Truck (A51039)
2005 Sterling...
