Mowing removeal of stored 1000 pto shaft to replace 540.
   / removeal of stored 1000 pto shaft to replace 540. #2
Sounds great. Hope you enjoy.
   / removeal of stored 1000 pto shaft to replace 540. #3
:confused:
   / removeal of stored 1000 pto shaft to replace 540. #4
Me to
   / removeal of stored 1000 pto shaft to replace 540. #5
see above .
Guess there is room for assumptions? To get the 1000 rpm shaft out you need to remove a large inside snap ring IIRC. I may be wrong but thinking back about forty years.
Try being a little more explicit, complete sentences may yield better responses.
   / removeal of stored 1000 pto shaft to replace 540. #6
I'm with Gator.
   / removeal of stored 1000 pto shaft to replace 540. #7
Ditto what jenkinsph stated. Remove snap ring(parts key #1) pull each shaft and interchange locations. If you'll point nose of tractor down in a ditch you'll loose less hyd oil. Also sometimes 1000 rpm shaft needs to be pulled,turned and reinstalled to get the drive splines of shaft & drive gear to line up.
   / removeal of stored 1000 pto shaft to replace 540. #8
Odd thing is that OP's profile says that he's a tractor dealer owner. If that's correct, I'd think he'd ask one of the mechanics.
   / removeal of stored 1000 pto shaft to replace 540. #9
I must kinda daft but what is being asked??
   / removeal of stored 1000 pto shaft to replace 540. #10
So if the OP is a tractor dealer why would you think his mechanic/technician would know how to interchange 540/1000 rpm pto stub shafts on a JD 4020 tractor??
2017 Freightliner Cascadia 125 Single Axle Sleeper Cab Truck Tractor (A50323)
2017 Freightliner...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A51039)
2016 Ford F550 4x4...
2022 FREIGHTLINER M2 24FT BOX TRUCK (A51222)
2022 FREIGHTLINER...
2018 FORREST RIVER CRUISE LITE CAMPER (A50854)
2018 FORREST RIVER...
19008 (A48082)
19008 (A48082)
2013 FORD F-450 UTILITY TRUCK (A51222)
2013 FORD F-450...
