Building a Pole Barn: Step 1
   / Building a Pole Barn: Step 1 #1
gregfender
Gold Member
Marion, NC
Kubota L2501 HST
So I think I have found the right plan that will fit perfect on the property and I can build myself. I think. I hope.
Over the years I have slowly increased my knowledge base and tackled larger and larger projects. However, This will be the largest one to date. I am handy with tools, can understand most blueprints, and careful about doing things right. That being said, What kinds of advice can you fine folks give me in regards to building a pole barn. Attached is the general plan for what I am wanting to build. I hope I am not getting too ambitious.
http://www.todaysplans.net/DB-Woodberry.pdf
  • Woodberry Pole Barn.pdf
   / Building a Pole Barn: Step 1 #2
Is that a pole barn? Looks more like a stick built barn on a slab.
Are you going to pour a concrete floor? If so, then going with standard framing methods used to build a house is how I would build that barn.
Eddie
   / Building a Pole Barn: Step 1 #3
Nice looking structure. It looks like a "do-able" project for one person. So many of the barns are for units that are 40' x 80' which I think would really be beyond single person projects. My only recommendation would be - be certain that the footings & foundation are adequate for the frost depths in your area. Neighbor put up pole barn - footings(sono tubes) were too shallow and seasonal frost tore his building to pieces. He isn't bragging about saving the cost of a building permit anymore!! Enjoy the project - it should be fun.
I will be pouring a slab floor. The plans call for 6x6 posts and 2x6 girts for the most part. I was just thinking pole barn framing would be a bit easier for me since this is my first structural build. My biggest concern is when I get to the roof. There are no trusses, just 2x6 rafters attached to a 2x8 ridge beam and collar ties. I just hope I can keep the rafters square as I go.
   / Building a Pole Barn: Step 1 #5
You know, I thought the same thing Eddie until I read portions of the plans. They talk about it being a pole barn - sure looks like a stick built structure to me also. No diff - it will be a nice structure.
   / Building a Pole Barn: Step 1 #6
As long as you keep your posts square it will make your work that much easier when it comes to building your roof. Even with trusses you can't just slap them down and call it good.
Definitely a pole building, no doubt.
   / Building a Pole Barn: Step 1 #7
First things first, I would start with a detailed Bill of Materials. This will help with making sure you've accounted for most if not all building materials required, quantities, etc., and will help with your budgeting. The plans look fairly straight forward and provide plenty of detail.
In order to determine the length posts you need, you first need to know what the frost line depth is in your area.
   / Building a Pole Barn: Step 1 #8
Yep, measure, measure, measure :) Take time at every stage to make sure everything is level and plumb in all directions, and square.
For working alone especially, a rotating laser level you set up on a tripod in a central location and carry the target around, would be a real help.
   / Building a Pole Barn: Step 1 #9
Very attractive building. The only comments I would have is that I would put overhead doors instead of the hinged/rolling doors. You can get them to look like the hinged doors. As far as do it yourself, the 12/14 roof would slow me down. I think I would bring in a contractor for that part. That's just me though. 6/12 is about as steep as I am comfortable with.
   / Building a Pole Barn: Step 1 #10
Are you going to finish off the interior walls? Insulate the walls and roof?
The advantage of a pole barn is that it's the least expensive way to build a barn. But if you are going to finish off the inside and pour concrete, it makes more sense to build it stick frame.
Eddie
Are you going to finish off the interior walls? Insulate the walls and roof? The advantage of a pole barn is that it's the least expensive way to build a barn. But if you are going to finish off the inside and pour concrete, it makes more sense to build it stick frame. Eddie
I'm going to finish off a part of the lower part and half of the loft. I am going to panel part of it with the weathered boards I salvaged from my Pappy's barn.
Eddie, what's your opinion on concrete thickness? The heaviest thing I have is 3100 lbs of tractor that I will pull in only for servicing, not for storage. Would 4" with rebar and fiber filled concrete work? I'm thinking 3500 psi. Any suggestions?
   / Building a Pole Barn: Step 1 #12
My names not Eddie but I'll chime in. 4" should be plenty. Back in my home building days we never poured anything thicker when doing driveways or garages for cars. Always used 2x4's for forms. Your tractor weight is about what a full size car nowadays weighs.
   / Building a Pole Barn: Step 1 #13
If you don't mind I'd also like to chime in on your question directed toward Eddie.
If you build it just like they say to you'll have a building that will last you many years, but like Eddie said, if you want to finish out the interior and switch to stick built, these plans go out the window.
Pay close attention to the minimum requirements, which you've surpassed with going with 3500psi concrete . . . they call for 3000 minimum. They also call for 6x6 #10 wire mesh. I know I've seen Eddie make the comment several times that mesh/rebar left on the bottom of the form does no good and this is very very true.
The biggest killer (cracks) of slabs is unstable/non-compacted fill. Again, follow the plan and you'll have a well built building.
Speaking of concrete, how should it be layered? I was planning on excavating 8-10", compacting the soil, adding 3-4" of sand, compacting that, then 2-3" of washed gravel, compacting again, then laying a vapor barrier down, setting the rebar or wire mesh on chairs, then pouring 4" of concrete.
Is that the right order, overkill, or the right approach?
   / Building a Pole Barn: Step 1 #15
Im not sure why you would want to excavate undisturbed soil to that depth only to fill it back with 4" of sand. I would skip that step and dig the depth for 4 inches of gravel under the slab. The rest of your steps sounds like a solid plan. Good luck. That's a beautiful building
   / Building a Pole Barn: Step 1 #16
On page 10 they call for a minimum of 8" clean (washed) gravel. In the concrete notes (Notes 3) they also call for the slab to be at least 2" thicker at all edges, this includes both sides of expansion joints that run along the centerlines of the posts.
I'm not so sure the sand is necessary, but maybe someone more knowledgeable could chime in. The vapor barrier and chairs are both good calls.
I had never really thought of it like that. I am so used to doing patios and such where the base layer of sand is what keeps the stones level. I sometimes forget that concrete levels itself!
   / Building a Pole Barn: Step 1 #18
NC is usually pretty warm, but are you going to heat it?
I am going to either put a barrel stove in it or putting a gas wall heater in. Initially, I will probably just go with a kerosene heater to knock the chill off.
   / Building a Pole Barn: Step 1 #20
Greg,
That is a nice looking building.:thumbsup:
Keep us updated with photos. Do you have a couple of friends that can help? If not it looks like a good project for a history class:laughing:
I plan on starting mine late winter early spring. I will get a local guy to put in the post and get it under roof then finish it myself. I need to take down about 10 trees before starting. I gave up on Morton way to many $$.
Are you buying your post from Lowes?
David
Willmar 4550 Wrangler Articulating Loader (A61306)
Willmar 4550...
2022 CATERPILLAR 242D3 SKID STEER (A60429)
2022 CATERPILLAR...
2019 COLEMAN BT200X MINI-BIKE (A60430)
2019 COLEMAN...
2013 COACHMEN CATALINA TRAVEL TRAILER (A55745)
2013 COACHMEN...
SWICT 78" SKID STEER BUCKET (A60430)
SWICT 78" SKID...
Deere 333E (A60462)
Deere 333E (A60462)
