Cheap Generator
   / Cheap Generator #1
dgeesaman
Harrisburg, PA
New Holland TC45DA
Hello,
We need an emergency backup in case of a power outage to keep the well pump and septic pumps running, and if there is spare capacity, a refrigerator and a couple of lights. We keep horses so the water has to flow.
Long term we'll get a good whole-home generator but right now I'm pushing it to spend $300 and I think that's enough. I want reliable and simple and cheap. Gas / propane / diesel, loud, stinky doesn't matter much.
How do you suggest I put $300 into a used generator that will be money well spent? What's the Ford 8N of small generators?
David
   / Cheap Generator #2
David, you will need to total everything you want to run (watts/amps ect tra) But these sold at cabelas are used by allot of RV'rs ( The champion models) Stand alone gensets will run much higher $$, these portables have many uses. I have a Onan 5500 in my Toy hauler and it is great, but expensive for emergency power, more for RVing.
Search Results : Cabela's
   / Cheap Generator #3
Not going to happen for that money ,sorry.You have a tractor I assume,so a PTO unit is the most bang for the buck.Look for used,auctions ,craigslist ect.
   / Cheap Generator
Maybe I need to revise my description a bit - a long term generator solution is not in this year's budget. No way, no how. I think a long term would be several kV and run off the propane tank we'll have for the range.
I'm definitely thinking used. New and cheap means big box crap construction and I'd rather have a rusty old thing that was built well than a newly painted, heavily stickered piece of junk. Hence my hope of there being a "Ford 8N" of used generators.
My need for emergency power is to run the well pump and septic pump. That's it. I want to something on hand to do this for a couple of years. Knock on wood, but it's not common for us to have power outages and thankfully I live on a major road and underground run to the house so I suspect service issues would be addressed quickly. I might drag it out a couple of times a year to help keep it from going stale by running an electric power tool out on the property.
So my options are no generator at all or a $300 generator. Or sell the tractor to buy a proper genset and transfer switch.
I hear about these PTO generators but I rarely see them. The ones I've seen run a few thousand dollars. I'd be happy to use the tractor for now but are there old/cheap/small PTO powered generators to be found?
   / Cheap Generator
Thanks, I've seen a couple of these for sale on CL.
I've also seen Colemans for sale, but my experience with Coleman is that all Coleman products are built as poorly as a Black and Decker.
David
   / Cheap Generator #6
Dont know how much power you need but I use a 1000 watt invertor to run stuff on the farm. I have a small gas engine (picked up a lawn mower someone had on the side of the road as junk) running a alternator from a junk yard hooked to a battery. The invertor was $89 from a Pilot truck stop and the alternator was $35 the battery was $79 at Walmart. I can run lights, drill even a small frig.
   / Cheap Generator #7
Problem here is you need 220vac for the well pump, which typically means a minimum of a 4Kw generator. I don't know of any generator, or inverter, rated at 3000watts or less that will supply the 220vac that the well pump needs. That well pump will also have a large inrush of current on startup to get the column of water in the pipe moving. You can find used 5 Kw generators for the money you are talking, but you need to be on top of the listings as they don't last wrong.
   / Cheap Generator #8
Yes, I'd say the well pump @ 220v is what's going to be hard to cover for $300. Don't know what the typical septic tank pump needs.
I you put hard numbers on those two requirements, you will know if a given gen. you see for sale is a fit or not. You can manually choose which of those is powered at any given time, so which ever is the largest power user, that's the one you need to aim at for gen. size.
   / Cheap Generator #9
I bought one of the Champion 3500 watt running 4000 startup watt generators several years ago, as we used to have one or two outages a year. At that time, they were $269 at TSC (with a coupon found on google). Side note: the electricity hasn't been off since I brought it home!
I initially bought that model because it came with the 30 amp RV outlet installed and I thought that if we ever decided to go dry camping, it would much easier to just plug the fifth wheel into the generator instead of patching things up to work. Later on, I worked out that if I did need to use it at the house, I could use my 40 foot RV extension cord to run 30 amp service into the house, then split that up into 2 15 amp outlet boxes to run whatever I needed to run.
I have used it several times out on the farm and I always try to start it up and run it at least every 4-6 weeks, then shutting the fuel off and letting it run dry. It's always started easily and I'm fairly impressed with the running time on a gallon of gasoline. This morning, it was 24 degrees in my unheated garage, but I turned the fuel on, waited a few minutes, threw the choke and it started hard enough to run on the second pull.
I usually try to buy American, but at the time I thought I needed a generator, this one was about all I could afford without talking over expenditures with the wife, but so far, I consider it to be a good investment.
You didn't give any specs on your well pump (110/220, amps, etc) or your septic pump, if they need to be running continuously or just a certain times, but if the wattage works out, I think you might want to look at the Champions.
   / Cheap Generator
I'll come up with the specs on the well pump. In my mind I hadn't pictured it being a major consumer but it's probably true it will be very peaky and startup current may be severe.
David
CATERPILLAR 259D3 SKID STEER (A52705)
CATERPILLAR 259D3...
2018 SOLAR TECH SILENT MESSAGE / LIGHT BOARD (A52705)
2018 SOLAR TECH...
2004 Ford F-250 4x4 Service Truck with Liftgate (A55788)
2004 Ford F-250...
Towable Message Board (A55787)
Towable Message...
2018 JLG 450AJ CLEARSKY MANLIFT (A52705)
2018 JLG 450AJ...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A55218)
2003 International...
