Cheaper oil filters
   / Cheaper oil filters
My goodness, what a fun thread with a lot of good feedback. Perhaps I should've asked if there's anybody out there that has had any kind of problems with what kind of filter. Then we could all just avoid that one! Thanks to all, Hal
"I may not do good work... but I sure am slow."
   / Cheaper oil filters #82
I see you're a new member. Looks like you're learning:D
   / Cheaper oil filters #83
I ran into that with fuel filters for by B2710. Turns out there was a design change Kubota made which ended up with some 2710 units taking one style and others taking another. Threy offer both but the cross reference is slow about catching these type of issues.
But in this case they are specifying a 50 micron screen instead of a diesel paper filter, I use better on my gasoline log splitter and generators.
David Kb7uns
   / Cheaper oil filters #84
While we are on filters it's worth noting that they drain much better if you drill or punch a hole in the bottom and drain upside down. In most of my filters, more oil comes out.
   / Cheaper oil filters #85
I also do that too. I have a funnel in a gallon oil jug I set them in after I punch a hole through them. I have noticed that usually there is very little oil that comes out of a fram in comparison to other filters.
Sent from my GT-P3113 using TractorByNet
   / Cheaper oil filters #86
What you COULD do is turn this into a good thread by helping others save money on filters.
Here'a a good tip. I have 2 pieces of equipment that have Mitsibushi diesels that run the same oil filter. One is on a Cub Cadet 7260, the oil filter lists for $18.00 dollars. However Subaru Justy engines used the exact same oil filter with the exact manufactures part number on it but lists for $8.95 direct from any Subaru dealer.
Part number 15208-KA012.
Fred
Cub Cadet FILTER-ENG OIL Part #MA-31A40-02101
Made by this company:
http://www.roki.co.jp/english/products/oilcenter_e.html
Utility Trailer (A52377)
Utility Trailer...
2016 Ford F-750 14FT Flatbed Service Truck (A52377)
2016 Ford F-750...
2024 KMC 7406 (A53084)
2000 GMC C7500 CRANE TRUCK (A51406)
2000 GMC C7500...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
Pallet of UV Solid Hardwood Flooring (A53424)
Pallet of UV Solid...
