Any one seen a drone?
   / Any one seen a drone? #31
I would suggest that before you start shooting at drones or any aircraft for that matter, you check your bank balance, 401's and the accommodations at the local jail and nearest federal federal institution...not to mention the yellow pages under "lawyer referral".
I think the generalization about "gun nuts" is a bit over the top; it certainly doesn't fit any of the "gun nuts" that I know; in fact, all of the gun owners I know are extraordinarily responsible, not only with their firearms but in their personal lives.
There are "gun nuts", and there are "gun nuts". :) They come in different flavors.
   / Any one seen a drone? #32
What is the legal daily limit on drones? Possession limit? Is there a season? What outfitters operate drone hunts in this area?
   / Any one seen a drone? #33
   / Any one seen a drone? #34
Get yourself a big RC plane and fly it into the drone. Call it an accident in uncontrolled airspace. They may be pissed but until they "prove" beyond a reasonable doubt that you had intent to swack their drone, its just an accident. "your honor I was just trying to get my RC plane up their to see what it was" or better yet: "I was trying to teach my son the joy of flying RC aircraft when this thing flew over our property and slammed into his RC plane. We may never again enjoy that father son bonding moment and we'd like to seek damages for their carelessness."
   / Any one seen a drone? #36
Like maybe "nuts with guns"?
It's a lot more complicated than that, which may be why "gun nut" bothers?
Hunting nut. Fishing nut. NFL nut. Racing nut. Sports nut (in general). Gardening nut. Tractor nut. Travel nut. Birding nut. Nothing pejorative in those descriptions.
   / Any one seen a drone? #37
I can't do a decent search from work as they have filters preventing looking up a lot of shooting sites. Most of this is back of the napkin figuring.
If you were shooting straight up in a vacuum, you壇 get an elevation of 19,460 feet (and zero upward velocity at that point) with a shotgun firing at 1100 fps. Projectiles need to be moving more than 200 fps to get skin penetration. You壇 probably want 3 to 5 times greater velocity to damage plastic or thin aluminum. Which means your effective vertical range is now only 9,560 to 13,760 feet.
But youæ±*e not in a vacuum and air resistance slows shot even faster. If I have the drag coefficients figured properly, the maximum altitude youæ±*e going to get with a single bullet fired vertically is about 7000 when it reaches zero velocity; and maybe 4000 tops for being able to cause damage to a drone. Buckshot decelerates even faster. You might get max altitude of 1000 feet, but effective damage only up to 700 feet. Thatç—´ enough to take out civilian and police grade rotor drones (mini-helicopters). Youæ±*e not going to take out a Predator or Reaper with a shotgun, and youæ±*e unlikely to get a hit even with a .50 cal machine gun in the 2 or 3 seconds of window you have while it buzzes past.
敵unshots can travel as high as 10,000 feet, and the wind takes them in unpredictable directions.
釘ullets fired vertically spend at least 15 seconds in the air, and many hang for well over a minute.
Can falling bullets kill you?, 26 Nov 2013.
"The buckshot typically used in a combat shotgun spreads out to a greater or lesser degree depending on the barrel choke, and can be effective at ranges as far as 70 m (75 yards)."
Combat shotgun - Wikipedia, the free encyclopedia, 26 Nov 2013.
"Most buckshot loads vary in velocity between 1,100 and 1,600 fps."
Buckshot Basics | Shooting Illustrated, 26 Nov 2013.
Best way to stop drones? Hire a lawyer.
   / Any one seen a drone? #38
And Birdshot has even less lethality when it falls on you.. I have had birdshot (7 1/2, 8, or 9 sizes) fall on me hundreds if not thousands of times, as we used to go to a pistol range that was downrange from the trap and skeet ranges. It is just like being in the rain. Wear a hat, and glasses and don't hold your mouth open and look up.:)
   / Any one seen a drone? #39
Be careful of shooting at drones..... sometimes they shoot back! :confused3:
2005 OVERLAND TANK KILL TRAILER (A50854)
2005 OVERLAND TANK...
2007 HYDRO-AX 764 MULCHING MACHINE (A51242)
2007 HYDRO-AX 764...
2012 INTERNATIONAL 4300 26 FT BOX TRUCK (A51219)
2012 INTERNATIONAL...
2013 CATERPILLAR 420F BACKHOE (A51242)
2013 CATERPILLAR...
2011 L3 MEP-806B GENERATOR (A51222)
2011 L3 MEP-806B...
2000 ADDCO DH1000 Message board (A49461)
2000 ADDCO DH1000...
