Starter problems for a Kubota
   / Starter problems for a Kubota #1
moonlit
Kubota 2410
Hi everyone. New member. I have a Kubota 2410. A couple weeks ago I went out to start it and nothing happened. I thought it was the battery ,bought a new one, still nothing, then I did the screw driver over the terminals of the starter solenoid, and the starter turned over. So I thought it was the starter solenoid, so I replaced the solenoid. I put a screw driver in the safety switch, because I read on one of the forums that someone said to try that. I even pulled it off, and checked it with an ohm meter, it checked out good. I even took out the starter key module, and checked the ohms between terminals.
I hate to bother people before turkey day. I hate the thought of carrying wood from the barn to the house, when it's zero degree and six inches of snow. :dance1:
I hope someone has any ideas.:confused:
   / Starter problems for a Kubota #2
Is there a relay that the key switch energizes that switches power to the starter solenoid? There usually is. Do you have a circuit diagram? What about fuses in the starter solenoid circuit? Without a diagram or understanding of how the circuit works, it is pretty hard to diagnose. On the key switch when you turn it to the start position, what color of wire is energized? where does it go from there? just keep on chasing it..We know that the starter solenoid is not energized to pull up, so why not? you have to figure out what is in the middle.
James K0UA
   / Starter problems for a Kubota #3
If you can jump it with a screwdriver I would say you have pretty much narrowed it to the ign switch or the wire from the switch to the solenoid. Shortcut fix would be a loop of wire from batt post of solenoid back to the trigger terminal with a push button switch in the middle, make it long enough to reach the dash area.
   / Starter problems for a Kubota #4
Are we sure there is not a starter relay?
   / Starter problems for a Kubota #5
I dont have a wireing diagram in front of me but a solenoid is not a high load draw that would normally need a relay.
Some have talked about a add on relay that deere puts on theres to correct a low voltage prob .
   / Starter problems for a Kubota #6
I dont have a wireing diagram in front of me but a solenoid is not a high load draw èthat would normally need a relay.
The only ones I have are Kioti's and they sure have relays. That is why we need his diagram.
   / Starter problems for a Kubota #7
The wire on a kubota b8200 goes from switch thru clutch saftey switch to starter.
Thats the only tractor I have a schematic for.
   / Starter problems for a Kubota #8
Aren't there three safety switches (Neutral gear, pto, and seat) ?
   / Starter problems for a Kubota #9
Could be , we dont have the wire diag. For his model.
1994 Peterbilt 379 Semi (A50514)
1994 Peterbilt 379...
2017 Nissan Maxima Sedan (A50324)
2017 Nissan Maxima...
AUCTION STARTS HERE @ 9AM (A51242)
AUCTION STARTS...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A52128)
Ditch Witch 6510A...
2017 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2017 GENIE...
2004 Ford F250 (A50515)
2004 Ford F250...
