Pole barn on plate?
   / Pole barn on plate? #51
I think we all agree a two-story building on dirt doesn't make any sense. Most in my neck of the woods choose pole barn type construction as the most economical for hay, equipment etc. They appreciate their decision to build that way means it will have a limited life over other more conventional methods (and is a lot less work and $$) because the poles they have built off of will start to rot the day they are placed in the ground.
I'm not claiming to be an expert on this, but I have done quite a bit of repair work on fences and a variety of buildings. In every case, the rot is at ground level and once you get into the ground, the posts look brand new. If a pole building has the water running away from the building and the posts are protected by the walls so they don't get wet or sit in water, then there is no telling how long the posts will last. The oldest I've worked on was close to a hundred years old and the posts where pine coated in tar.
There is so much strength from a post in the ground to support the wall that it doesn't make much sense not to do it. Drilling the holes is simple enough. I've done it with a friend and a hand held post digger that we rented, and I've done it with a 3 point post hole digger. Then putting them in the ground and lining them up is just a matter of running a string and several long tapes to the corners to get it all squared up. Once this is done, the rest is a piece of cake. What contractor with any experience wouldn't do this is beyond my comprehension and a HUGE red flag.
Eddie
   / Pole barn on plate? #52
New England is rockier than most places. A lot of places the ground is mostly rock with a thin sprinkling of soil. A rock the size of a car is considered "medium-sized." Maine is rocky by New England standards. Generally, you're not going to be able to drill a row of holes with a 3-point post hole digger. For residential construction the usual practice is to dig until you hit something that doesn't move. If you must have a basement you blast it with dynamite, otherwise you leave it and pin the foundation to it with rebar.
I have three buildings on my property from the 1800's with basements. They didn't dig basements back then, only a fool would. The floor of the basement is at the original grade, a stone foundation was built on it and "dirt" (mostly rocks) was piled up around the sides so the building is on a little hill. An untreated 6x6 sill rests on top of the foundation wall and is held only by gravity and friction. There are many buildings around here that have lasted 150 years or more using this construction. The walls of the basement are desk-sized rocks they found lying around the property. I still have a few more...
I'm not saying the proposed construction is a good idea, just that a pole barn isn't always possible. I think that may be what the contractor is saying in a roundabout way.
   / Pole barn on plate? #53
I'm not familiar with building in New England, and appreciate hearing about it. While I can understand the difficulty of drilling through rock, I would think that if rock is there, then bolting to it sounds like another option.
Eddie
   / Pole barn on plate? #54
Regarding modern stick built residential construction on top of a concrete slab...
My wife used to work for a large residential builder in the Dallas area. One of their "better than the other guy" selling points was that they not only nailed the base plate down, but they also put anchor bolts down through the base plate every four feet. Said it was tornado proof.
I just laughed when I heard that. Okay, maybe the base plate is tornado proof. But all the vertical studs are still only nailed down to that base plate. If a tornado hits your house, you're going to be left with a slab and a base plate instead of just a slab.
xtn
   / Pole barn on plate? #55
Eddie
I'm no expert either, and I'm certainly not disputing the strength of pole type of construction. When putting up a building recently things I wanted to consider were longevity and costs. From what I learned talking to local builders, farmers and people like me who just have a few hay-burners and need some shelter and hay storage, is that a pole barn construction is considerably cheaper to build but will not last as long as a building with pressure treated sills on concrete up off the ground. The discussions then turned to which method to use; is a building on block going to last as long as a building on footings / four foot frost walls, I don't believe so but I am uncertain how much of a difference there is in longevity between the two types of construction while I do know it is considerably cheaper to build on block.
As always of course site preparation is key, you still need to clear all top soil, bring in clean dirt and properly compact and grade the site prior to laying the block. If you do the proper prep work it would be interesting to know the difference in lifespan of two identical buildings, one built on block and one on footings / concrete wall. Would make for an interesting discussion.
   / Pole barn on plate? #57
I have to disagree with you. Nothing is going to be cheaper then putting poles in the ground, especially if you are not planning on pouring a concrete pad. If you are pouring a pad, the cost of the concrete becomes a factor in comparing pole construction to stick built. If there isn't going to be a concrete floor in the pole barn, it's easily half the cost of any other type of construction except maybe building it on skids for a small structure kind of what the OP asked about. Of course, I would consider any building on skids, or just a heavy duty sill plate to be a temporary structure, not a building that will last.
Using block requires a concrete footing. Digging this footing to the required depth will vary in cost depending where you are located. Some places, like here, it's just a foot because we don't have any freezing concerns. If you have to do down several feet, then this becomes quite expensive. Then there is the rebar and the cost of concrete before you even get to the blocks and what they cost.
Eddie
   / Pole barn on plate? #58
So let me describe a bit more one of my buildings.
I have a barn that is 36x28, 16' at the eave. It is post and beam, which is actually similar to pole barn construction, think of it as a pole barn built without metal fasteners and without digging holes. It has a dry-stacked stone foundation. On the foundation is a 6x6 untreated sill all the way around. The sill is not fastened to the foundation in any way. The frame of the barn is 6x6x16 posts on 12' centers, four on each side. There is a 6x6 top plate that rests on top of the posts, and rafters support the roof. Between the posts are 2x4's that hold the 1" board sheathing. It has a lot in common with a pole building, it might even be considered flimsy by modern standards.
According to the tax records, this building was built in 1850. The oldest building in town has essentially the same construction, with hewn beams instead of sawn. It was built in 1690.
I guess my point is it is possible to build a long-lived building on just a heavy sill. I think you really need to know what you're doing though.
   / Pole barn on plate? #59
Eddie
Actually Eddie what I had said in my post was that "pole barn construction was considrably cheaper to build", no argument there. As far as using block requires using concrete footings, not necessarily the case. Remove top soil down to the hard pan, replace with sand, compact that and then lay your block, invert a course of starter shingles so your wood doesn't touch the concrete, water seal 6x6 PT sills and then stick frame on top of that. I would suggest that this construction method sits between pole barn (cheaper) and a stick frame building on concrete walls with footings (considerably more expensive) as far a longevity goes, and only because of the potential for damage caused by heaving that can occur with a building resting on block on grade.
   / Pole barn on plate? #60
Whew, I thought I knew something! I don't know nary a thing! But, I'm full of questions. I'm planning to build about 36'x36' (maybe 36'x40') this summer, pole barn or post/beam type. Okay, I am planning to dig holes about 8' on center (will change this as necessary, maybe 6' or 10' on center), 3' deep by about 8" square form and pour concrete in the forms up to where all of them are level. Can y'all picture what I'm talking about? It'll be a heap of concrete square "posts" sticking up all level at least 8" above ground level at the lowest point. I'll insert those galvanized post attaching thingamabobs while concrete is still soft and attach me 6x6 ground contact treated posts to them when cured. Then I'll run treated boards around the bottom of posts, notch out for headers at top (10' at eaves) and put up me trusses. I'll put plenty of boards laterally around the barn to later attach siding when I can afford siding.
I'm in Georgia, so hard clay dirt, but don't want me posts in ground. I'll do work meself with helper. So, Eddie, what ye think about me plan? I know you're a builder, so I trust your advice.
2017 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4x4 - Versalift SST40 Boom (A52748)
2017 Ford F550...
NEW Fork Extensions (A53002)
NEW Fork...
New Holland LX885 Skidsteer (A51573)
New Holland LX885...
2013 MACK CXU (A52472)
2020 COLOMBO TM LOT NUMBER 216 (A53084)
2020 COLOMBO TM...
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A52748)
2019 New Holland...
