EddieWalker
Epic Contributor
I think we all agree a two-story building on dirt doesn't make any sense. Most in my neck of the woods choose pole barn type construction as the most economical for hay, equipment etc. They appreciate their decision to build that way means it will have a limited life over other more conventional methods (and is a lot less work and $$) because the poles they have built off of will start to rot the day they are placed in the ground.
I'm not claiming to be an expert on this, but I have done quite a bit of repair work on fences and a variety of buildings. In every case, the rot is at ground level and once you get into the ground, the posts look brand new. If a pole building has the water running away from the building and the posts are protected by the walls so they don't get wet or sit in water, then there is no telling how long the posts will last. The oldest I've worked on was close to a hundred years old and the posts where pine coated in tar.
There is so much strength from a post in the ground to support the wall that it doesn't make much sense not to do it. Drilling the holes is simple enough. I've done it with a friend and a hand held post digger that we rented, and I've done it with a 3 point post hole digger. Then putting them in the ground and lining them up is just a matter of running a string and several long tapes to the corners to get it all squared up. Once this is done, the rest is a piece of cake. What contractor with any experience wouldn't do this is beyond my comprehension and a HUGE red flag.
Eddie
