Ram1500 EcoDiesel V6 revealed!
   / Ram1500 EcoDiesel V6 revealed! #291
I would like to see your door sticker. That is the real number after subtracting all your options. Aftermarket air bags add nothing to the legal payload capacity. Here is my sticker on an 2011 f150 ecoboost supercrew 2wd.
GVWR sticker. What jumps out at you about this one, in comparison to your Ford.
Payload Sticker
   / Ram1500 EcoDiesel V6 revealed! #292
Based on your second pic, your payload is 1256. Adding air bags doesn't increase the payload, it just helps it carry the weight more level.
   / Ram1500 EcoDiesel V6 revealed! #293
I guess you only see what you want to see.
The Ram's suspension has a higher rating than the Ford, but Ford then rates their payload and gvwr higher.... so which company is fudging the numbers.
   / Ram1500 EcoDiesel V6 revealed! #294
Ummm, I'm just reading what's on the sticker. So, tell me where I'm "seeing what I want to see." Seriously, I'm not making anything up, just reading what I see.
You do realize that there is more to calculating the payload than just using the axle ratings, right? You saying Ford is fudging numbers is "seeing what you want to see", not my reading directly what's on the stickers.
Geez, dude!
   / Ram1500 EcoDiesel V6 revealed! #295
The Ford GVWR (7350#) is rear GAWR (4050#) + front GAWR (3600#) -300#. On the Dodge (6800#) it is rear GAWR (3900#) + front GAWR (3900#) -1000#.
Perhaps Dodge trusts their suspension more than they trust their frames?
Aaron Z
   / Ram1500 EcoDiesel V6 revealed! #296
Maybe life is better on the north side of the border? Tar Sands here I come..........
   / Ram1500 EcoDiesel V6 revealed! #297
Geez, dude!
Aczlan got it.
When I'm driving commercially, it's the individual axle ratings that I have to look at, because that's what the scale operator is going to be looking at.
   / Ram1500 EcoDiesel V6 revealed! #298
Alberta - Strong employment, and lots of pickup trucks - What's not to like ? :)
Your oilpatch is doing very well too.
Rgds, D.
   / Ram1500 EcoDiesel V6 revealed! #299
Aczlan got it.
But my point still stands. The maximum payload on that truck is 1256 lbs. Period. It doesn't matter if the axles are rated at 50k lbs. The payload is 1256. There are many factors that limit the rating on the truck from the tires to the frame to the axles to the brakes, etc. We don't know exactly what the limiting factor on your truck is, but we do know it's NOT the axles. This isn't brand biasing, this is fact.
So, could you show me where I'm "seeing what I want to see"?
   / Ram1500 EcoDiesel V6 revealed! #300
Aczlan got it.
Avoid the US. The first thing they will look at is what you are registered for. Exceed that and you are going to pay no matter what your truck is rated for. The next will be the weight ratings on your tires. Since anyone can upgrade the suspension and brakes the door sticker means little to the DMV.
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A55315)
Galvanized...
2011 Ford Econoline Cargo Van (A54814)
2011 Ford...
1996 Parker Trailers TravAlong T/A Gooseneck Livestock Trailer (A55787)
1996 Parker...
John Deere 2040 Utility Loader Tractor (A55851)
John Deere 2040...
2011 COMPTANK  ACID TRANSPORT TRAILER (A55745)
2011 COMPTANK...
2024 Cynergy Cargo 2 Enclosed Trailer (A53117)
2024 Cynergy Cargo...
