2013 Tundra oil change interval
   / 2013 Tundra oil change interval #11
Toyota Lexus Scion Special Oil Filter Wrench Tool V6 V8 Filter Cap 15620 31060 | eBay
Here you go.
You get the wrench and an aluminum cap.
If the perforated tube in the middle of your plastic cap is a different length than this replacement - bend the two ears, swap them out, then you are good to go!
Why Toyota uses aluminum on some and plastic on others, who knows, but it works great. Check out tundratalk and it is a popular and proven modification, that is where I learned of it.
   / 2013 Tundra oil change interval #13
dusty--excellent and thank you.
The wrench is especially nice.
   / 2013 Tundra oil change interval #14
The service interval on our VW TDI is 10k miles. I thought it had gone to 15k miles on gasoline engines, with synthetic oil in both cases.
I switched to 0w20 oil on our Tacoma 4 cylinder. Better mileage. Think most of it is pumping loss reduction. Doubt there's any friction difference.
Ralph
   / 2013 Tundra oil change interval #15
I called the dealer today as we are nearing the 5k mile mark to schedule the 1st oil change. Since it has 24mo/24k mile free maintenance, I figured I would take advantage of it. The service writer told me I am only due for a tire rotate, oil change intervals are 10k miles and 5k on severe duty schedule. This is also in the manual. I am wondering if this interval increased when they offered the free maint program. The truck, per the svc writer, has 0-20w synthetic, allowing for the 10k mile change interval. Hmmmm....thoughts?
I have a 2007 Tundra, and they notified me of the increase to 10k before I saw any mention of the free maintenance program. I'm not even at 60k because I have a work car, and it has always gotten synthetic oil, so I don't think too much about it either way.
   / 2013 Tundra oil change interval #16
10K with modern synthetics is not a issue
Chris
   / 2013 Tundra oil change interval #17
You should all remember, although synthetic oil can go the distance, very few oil filters will.
   / 2013 Tundra oil change interval #18
Till now, not one person mentioned that.
   / 2013 Tundra oil change interval #19
dirty oil is dirty. dirty oil bad. synthetic is great, but not if its dirty. high interval oil changes make cost of ownership / maintenance prices look lower making the manufacturer look good on paper. look at how many more engine jobs Toyota is doing now compared to older models, same w/ bmw. I do fleet maintenance for a couple of different companies w/ many different makes & models. many have well over 200k. what they all have in common is regular maintenance, 3-4k miles between. one livery car 440k runs like a clock. lof every 3k no more. that's a 2004 mercury grand marquis.
   / 2013 Tundra oil change interval #20
The aluminum oil filter housing is a great up grade over the OE plastic 1. I ordered mine from Toyota for a Toyota venza. You'll have to remove the center tube in the aluminum housing and replace it with the 1 out of the plastic housing. What puzzles me is, why did Toyota put this cheap plastic housing on these trucks and put a heavy duty housing on a venza ??? I made me a wrench like this 1 B-4 this one came on the market. I should have gotten a patent on mine
2022 Ligchine Spiderscreed Concrete Screed (A59228)
2022 Ligchine...
1992 DFI PULL SPREADER (A57192)
1992 DFI PULL...
2016 PETERBILT 365 (A58214)
2016 PETERBILT 365...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2013 Ford Focus Hatchback (A59231)
2013 Ford Focus...
2019 Dorsey DF40 40ft. 40 Ton T/A Drop Deck Flatbed Trailer (A60460)
2019 Dorsey DF40...
