Davis Split bucket.. What for?
   / Davis Split bucket.. What for? #1
Desert Bred
Goodyear AZ
1998 CKC TS 254 (Fei Dong 295T1)
Found this loader. Why is the bucket split into two sides?
Also, if anyone is familiar.. this Davis has its own pump.. why? is it normal?
i know it's older..
   / Davis Split bucket.. What for? #2
I think that's there to reinforce the bucket. My loader doesn't have one and the cutting edge was bent into a smile when I bought the tracror.
ah ha!
   / Davis Split bucket.. What for? #4
+1 on the bucket divider - also, you didn't say but I'm guessing the pump is a PTO pump - I have two older tractors, wanted more remotes - discovered that the only place I could get a hydraulic feed was by cutting METRIC tubing and re-routing it, and TEE-ing into a 1" low pressure line for return.
Others have used rear remotes to run a loader. I'd almost rather use a shovel and pain killers, YUCK!!!
Plus, most older tractors have fairly low flow systems so a loader would be kind of sluggish in operation.
The PTO typically has nearly as much horsepower available as the tractor, so a PTO pump can fix ALL the shortcomings.
HTH... Steve
   / Davis Split bucket.. What for? #5
The pump might be designed to mount on the front of the tractor, driven by a coupling on the crankshaft pulley.
On some tractors the shaft goes through the axle.
Does the loader tower have the hydraulic oil reservoir built into the loader frame, like mine?
It came with a pump also.
Walking Floor Trailer (A50322)
Walking Floor...
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A52128)
2007 Freightliner...
2008 JLG 450AJ SERIES II TELESCOPIC MANLIFT (A51242)
2008 JLG 450AJ...
2015 CATERPILLAR 326FL LONG REACH EXCAVATOR (A51242)
2015 CATERPILLAR...
SELLICK S80J4E-2PS ROUGH TERRAIN FORKLIFT (A51242)
SELLICK S80J4E-2PS...
LAMAR 20 T/A TRASH TRAILER (A50854)
LAMAR 20 T/A TRASH...
