Davis Split bucket.. What for?
/ Davis Split bucket.. What for? #1
Desert Bred
Goodyear AZ
1998 CKC TS 254 (Fei Dong 295T1)
Found this loader. Why is the bucket split into two sides?
Also, if anyone is familiar.. this Davis has its own pump.. why? is it normal?
i know it's older..
/ Davis Split bucket.. What for? #2
I think that's there to reinforce the bucket. My loader doesn't have one and the cutting edge was bent into a smile when I bought the tracror.
ah ha!
/ Davis Split bucket.. What for? #4
+1 on the bucket divider - also, you didn't say but I'm guessing the pump is a PTO pump - I have two older tractors, wanted more remotes - discovered that the only place I could get a hydraulic feed was by cutting METRIC tubing and re-routing it, and TEE-ing into a 1" low pressure line for return.
Others have used rear remotes to run a loader. I'd almost rather use a shovel and pain killers, YUCK!!!
Plus, most older tractors have fairly low flow systems so a loader would be kind of sluggish in operation.
The PTO typically has nearly as much horsepower available as the tractor, so a PTO pump can fix ALL the shortcomings.
HTH... Steve
/ Davis Split bucket.. What for? #5
The pump might be designed to mount on the front of the tractor, driven by a coupling on the crankshaft pulley.
On some tractors the shaft goes through the axle.
Does the loader tower have the hydraulic oil reservoir built into the loader frame, like mine?
It came with a pump also.
2017 International 4300 Box Truck (A62613)
2017 International...
Bad Boy Stand On Mower (A64047)
Bad Boy Stand On...
HARDEE DITCH BANK MOWER PARTS (A63291)
HARDEE DITCH BANK...
CASE INTERNATIONAL 6088 RWD COMBINE (A63291)
CASE INTERNATIONAL...
DRILL CABINET SKID (A60736)
DRILL CABINET SKID...
YANMAR VIO35-6A EXCAVATOR (A63276)
YANMAR VIO35-6A...
