Pallet forks suppose to be loose or SSQA bracket improperly made?
   / Pallet forks suppose to be loose or SSQA bracket improperly made? #1
Fallon
Super Member
Parker, CO
Kubota L4060hstc, formerly L3200hst
I just picked up a Quick Spade & when I went to test it out I noticed my forks were really loose. When I actually looked, the pins for the SSQA on the tractor had over a half an inch of space between the pins & the holes on the bottom of the fork frame. Are they suppose to be loose so they will self adjust a little when you are grabbing or dropping a pallet, or is an manufacturing problem? I hadn't had any issues with the forks previously. Thinking back they were a bit loose, but I didn't pay any attention. Now that I'm actually looking at things now & I'm thinking that slop will be beating up the SSQA pins or popping loose here sooner than later. The lever on the SSQA is all the way down in this pic & the pin engages tightly on my bucket. The frame on the forks does't look beat up, twisted or tweaked at all, so I'm pretty sure it was made that lose, right or wrong.
They are a set from palletforks.com & I seem to recall some people complaining about some problems with a SSQA on some forks from somewhere a little while back.
   / Pallet forks suppose to be loose or SSQA bracket improperly made? #2
They are supposed to be tight. You need to weld in some shims.. easy peazy fix.
   / Pallet forks suppose to be loose or SSQA bracket improperly made? #3
I have the same set and mine are just like yours. It does seem a little loose to me also but I moved over 1000 4x5 round bales with mine this year and the clearance didn't change from new. Never came loose either. I've thought about welding a tab over the hole to make it fit tighter.
   / Pallet forks suppose to be loose or SSQA bracket improperly made? #4
You should repair them. The grapples and forks, that were sloppy, have occasionally come off on one side and they usually twist the SSQA adapter. At least that has been reported here. My EA forks were just a little bit tight, I had to take a file to the hole to make the pins lock in easily. I would get out the welder and fix them.
James K0UA
   / Pallet forks suppose to be loose or SSQA bracket improperly made? #5
Never thought of it twisting the mount, that would be bad! Looks like a project for this weekend. Thanks for the motivation.
   / Pallet forks suppose to be loose or SSQA bracket improperly made? #6
Yep better safe than sorry, What usually twists is the tube that goes between the two pads, Far easier to fix the holes with a shim than to fix that darn tube. Good luck
James K0UA
Thought so, was looking for confirmation. Will get them sorted out here as soon as I can.
   / Pallet forks suppose to be loose or SSQA bracket improperly made? #8
I bought a set of forks off of Titan and mine are loose also. I guess I'll fix them this winter when I get around to it. You would think they would address this problem some time.
Jeff
   / Pallet forks suppose to be loose or SSQA bracket improperly made? #9
For whatever reason SSQA manufacturers don't seem to be able to keep their manufacturing dimensions where these pins lock in within spec. Forks don't need as tight of a fit as say a grapple, but your's look to be quite far off of spec. Titan used to refund a dollar amount for you to get a local welder to fix it. I would contact them.
   / Pallet forks suppose to be loose or SSQA bracket improperly made? #10
I don't understand why some of these manufactures cannot seem to keep the spec tighter. My EA manufactured Grapple was perfect. My Construction Attachment Forks which I bought thru EA had to be filed just a tad. It was a 5 minute job so no big deal. The 3rd party SSQA plate I welded onto my old Pin on Kubota bucket, fit my Kubota SSQA adapter perfectly but when I kept it and put in on the Kioti, I had to file it just a little bit also. So it seems there are some differences even in the adapters.
James K0UA
We're sorry about the fit issue you are experiencing! I have a few options for you: if you know how to weld or know someone who does, some 1/4" shims welded in the top bracket of the pallet fork attachment should make it nice and tight. We could refund you some to offset the cost/ time of doing this. We can also do a frame swap for you. This won't be able to be set up until Monday and the holidays would delay the shipment of your new frame. Please let me know how you would like to proceed. Thank you for the picture too. It is always informative to be able to lay eyes on the issue.
Nice prompt response. Need to figure if I want to deploy my meager welding skill on it or have em swap em out.
   / Pallet forks suppose to be loose or SSQA bracket improperly made? #12
My welding skills are somewhat limited but if it were me I would take the partial refund and weld shims in myself. Nice to see a quick response and good customer service these days, seems like an almost lost thing.
   / Pallet forks suppose to be loose or SSQA bracket improperly made? #13
why dont you get some 1/4 inch materiel and practice making some lap joints. and then go for it. Did you see Chucke2009 posting his welding series yesterday? He covers lap joints. It will be less hassle to do it yourself, and you will feel very good about doing it.
James K0UA
   / Pallet forks suppose to be loose or SSQA bracket improperly made? #14
Good, they did step up as I thought and as they have for years. I have 3 of their devices and two were perfect, one was not.
It still blows me away as to why Titan and others don't just put some quality control in place, it would have to be less expensive for them.
   / Pallet forks suppose to be loose or SSQA bracket improperly made? #15
Had the same problem with mine, Titan bent over backwards to resolve the problem.
L2800 w/FEL - 72" Land Pride rake
   / Pallet forks suppose to be loose or SSQA bracket improperly made? #16
   / Pallet forks suppose to be loose or SSQA bracket improperly made? #17
As to your welding skills. In this case it won't take much to hold shims in place. If you can goober up a bead on each end/side of the shim it won't move. Not like it's carrying any load and is being smashed into place when the forks are loaded.
   / Pallet forks suppose to be loose or SSQA bracket improperly made? #18
   / Pallet forks suppose to be loose or SSQA bracket improperly made? #19
I as wanting to get a pair of pallet forks & bail spears form PalletForks.com but with so many saying they need to have them fixed before they use them by welding on a shim I haven't done it. I have no way to do that or take they to be done. I didn't want to take the risk with my SS check.
   / Pallet forks suppose to be loose or SSQA bracket improperly made? #20
I wonder how many others read about the problems and decide to buy elsewhere. You would think that it would be a priority to fix the problem.
Jeff
ATHENS PLOW CO. 55-7' DISC HARROW (A60430)
ATHENS PLOW CO...
2009 Sterling Acterra Altec DM47TR Insulated Digger Derrick Truck (A60460)
2009 Sterling...
SWICT 72" SKID STEER BUCKET (A60430)
SWICT 72" SKID...
SWICT 66" SKID STEER BUCKET (A60430)
SWICT 66" SKID...
401 (A52706)
401 (A52706)
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
