Blower questions for a kubota l3540
   / Blower questions for a kubota l3540 #21
Wow that is surprising because I have a LA2674 Kubota snow blower on my L3540 and it doesn't miss a beat even with heavy wet snow. I've had a BX23 TLB and a B3200TLB with front and rear snow blower and both worked just great. You didn't say in your profile where you are located but I'm in up-state New York Close to the Adirondacks and we usually get heavy snow falls. Last week we received 14" of snow and like usual no issue with the 74" blower. My driveway is about 200' with a large turn around for RV's (8000sf blacktop) and I also clear around barn and carport. Not sure why your having an issue but you shouldn't, tractor with Hydro should blow very efficiently as speed of tractor is controlled by driver. I'm quite sure you have checked out your blower to make sure all is working well within tolerances, but something seems wrong, best of luck to you.
DevilDog
Any up date as to how the tractor and blower are working out? Can the tractor handle it? I have a L3540HSTCC and have a 74" Kubota blower but find the tractor under powered for it. I also have a B3030HSTC with a 60" Ecnor (Normand) blower and it works far better than the L3540.
   / Blower questions for a kubota l3540 #22
DevilDog
I had the tractor and blower in to the dealer last week and they did some checking and adjustments on the tractor. It is holding speed better on a small hill I travel up and down on my snow blowing route and the blower does blow some better. However, I would still have to say the B3030 is the better blowing setup of the two.
Killbros 1135 Grain Cart (A59814)
Killbros 1135...
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A57454)
New/Unused AGT...
2015 MACK CHU613 DAY CAB ROAD TRACTOR (A58375)
2015 MACK CHU613...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
CAT Chassis Only (A59076)
CAT Chassis Only...
