Bought this flail mower
   / Bought this flail mower #11
Takes a banded belt, don't think they're available thru NAPA. Got mine from a tractor dealer, might have been McGees. Parts diagram calls for size B57, but I found that to be too long. Have a B53 on mine, but there's enough take-up in the idler adjust to use a B54 inna pinch. Having said that, I'm assuming all 917s use the same belt. Check your specific parts diagram to be sure
//greg//
   / Bought this flail mower #12
Looks like you have it figured out, but just wanted to add some info., albeit late.
Definitely 917 or 917A. If bracket for gearbox that bolts to frame is Z-shaped, then 917. If U-shaped, then 917A. Gearbox was used on 907, 917, 917A and 917H. 917L had a square gearbox. 917H has a welded back skirt instead of bolted.
Thanks TractorTech. I appreciate your feedback. Hopefully the old gal has a lot of productive hours left in her without a lot of maintenance issues.
2016 FORD F-250 PICKUP TRUCK (A52576)
2016 FORD F-250...
197711 (A51244)
197711 (A51244)
2016 Ford F-350 Ambulance (A51692)
2016 Ford F-350...
NEW Skid Steer Bolt on Hay Forks (A53002)
NEW Skid Steer...
2015 PETERBILT 389 TRI-AXLE MID-ROOF SLEEPER (A52472)
2015 PETERBILT 389...
2016 Chrysler 200 Limited Sedan (A51694)
2016 Chrysler 200...
