rScotty
Super Member
- Joined
- Apr 21, 2001
- Messages
- 9,557
- Location
- Rural mountains - Colorado
- Tractor
- Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
Just a quick thought working from the toe lift idea, could you mount another pedal just to the side of the forward control and set it up like a teeter-totter. Pressing down on it would raise the forward pedal, the same way your toe would. It might be pretty simple to construct and would leave the existing mechanism unaltered.
Good luck.
I also wish for a side by side F/R HST pedal. That's one of the things that JD got right on their mid-size HSTs and I miss it. It used to be that I didn't mind going from one motion to the other, but as I get older the JD side by side pedals are easier on my hip, knee,and ankle joints.
Although I find the Kubota OEM HST pedal to be uncomfortable it is certainly very well made and the idea of modifying things as little as possible is appealing. Using a lever mounted to the left of the existing mechanism to work by forcing the toe of the lever up - the toe-raise idea - sounds like it is worth looking into. I'm going to take a look at that today....try to figure out the forces on the pivot.
Is it possible to simply rotate the HST control CW by 90 degrees? Can that be done? Would it accomplish some part of what we want?
rScotty
