Kubota HST Side-by-Side Pedal Modification
   / Kubota HST Side-by-Side Pedal Modification #81
JUst another thought here. Is the clutch on a Kubota an actual clutch or is it just a hydraulic dump. If you don't like the clutch on an hst can you not just remove the pedal? Or unhook the wires if it's just a hydraulic dump?
It is an actual clutch. Added mechanism for not benefit. It does make a mechanical break between the engine and the rest of the tractor which could be used as an emergency stop on the pto.:confused3:
   / Kubota HST Side-by-Side Pedal Modification #82
The main clutch is much larger and cheaper to replace than the pto clutch pack. Fantastic for starting large pto loads where other CUT's would not last long. Feathering the pto clutch pack not recommended, use the main clutch.
2022 JCB 3TS-8T Teleskid Loader with Telescopic Boom, DB84 Dirt Bucket and FAE Mulcher (A52128)
2022 JCB 3TS-8T...
2008 Ford F-250 XL (A50323)
2008 Ford F-250 XL...
2012 Ford Escape Limited SUV (A50324)
2012 Ford Escape...
UNUSED JCT SKID STEER QUICK ATTACH AUGER SET (A51244)
UNUSED JCT SKID...
BUSH HOG 32601 - 6' ROTARY MOWER (A51243)
BUSH HOG 32601 -...
2015 DODGE RAM...
