F250 6.2 V8 vs F150 Ecoboost
   / F250 6.2 V8 vs F150 Ecoboost
A quick glance at Build Your Own on the Ford site would not show a gas engine option for the F450 and F550 and the F350 showed the 6.2 V8 as the only gas option. Looks like the V10 is gone for model year 2014.
   / F250 6.2 V8 vs F150 Ecoboost #102
The V10 I had was OK except for the spark plug issues and the rotting exhaust manifold bolts that even the Ford dealers call a time and material repair. No flat rate...How about that for standing behind an abysmal mistake.
I know the diesels have been down a hard road as far as improving reliability and mileage per gallon of fuel, but if the 6.2 V8 is similar or close to the V10, is newer technology with improved mpg and no widespread problems....sounds like a good move. With all considered think I have decided and will hold out another year or so and look for a year or two old unit with 30,000 to 40,000 and see if I can save a little off new and move up to the F250.
   / F250 6.2 V8 vs F150 Ecoboost #104
I recently bought a 2013 F250 6.2 4x4 which I use to haul a Kioti CK30 TLB. Pulls great and gets approx. 10 mpg. I have also pulled my 14' dump loaded with 10,000lbs of rock. Again no problem, I think you should always go heavier if possible and practical.
Is the 10 mpg towing or empty? Running 3.73 gears or the 4.30? What was previous vehicle and is this a daily driver?
   / F250 6.2 V8 vs F150 Ecoboost #106
1) what will the gross weight of the trailer be?
2) what are the heaviest tow ratings of the f150 and f250 (tow packages needed)? then tak it from there. I noticed a couple of posts saying the f150 is overloaded at 11500lb. Doesn't this cancel your insurance in an accident?
   / F250 6.2 V8 vs F150 Ecoboost #107
Nope. You would have to be grossly over weight ( thus deemed negligent ) to be held financially liable, and only then after your liability cap is reached.
   / F250 6.2 V8 vs F150 Ecoboost #108
My 2 cents worth,
1) I would check with my insurance company, maybe get in writing, before I bet my financial security on this statement.
2) I have been in reverse situation of the OP. I just went from a 2003 2500HD with Duramax/Allison to a 2014 GMC 1500. Both crew cab short beds, 4WD. I no longer needed the towing capacity of the 2500. I tow a pontoon boat, a covered trailer, and about once a year, my tractor on trailer. The tractor and trailer weigh about 8500 pounds, and GMC has capability of 9600 pounds, as optioned. I has the 2500HD for 9 years.
I can say after driving the 2500HD for years, and comparing to the new truck, (have not towed with the new one yet), that if I ever need to upgrade to tow over 10K, I'll go back to a 3/4 ton. I understand the book says the 1/2 ton Fords and GMC/Chev properly optioned are capable of 11K, but my opinion, and for my comfort, they don't have the "gravitas" to handle that kind of weight. Again, that is my opinion.
If I were in the OPs shoes, I'd go the 3/4 ton. In my situation, I could go to 1/2.
Have managed to hold out another year with the 2004 F150 FX4 4WD with 5.4 V8 and 3.73 rear end. Truck now has 155,000 miles and is due for minimum front brake rotors and pads. Will need new tires in 10,000-15,000 miles. Probably need new rear brake pads. Have the typical "tick" from cam phasers and has for over 100,000 miles. Have a little noise from rear differential when turning. Not sure if is clutches just making noise or sign of worse issues. Made several 30 mile trips moving 5303 4WD tractor, with loader and implement on 22' bumper pull 12k trailer with brakes on all axles. Still wind up back and forth between the F150 and F250. With kids getting older and into more activities we are finding ourselves on the road traveling more and more. Most often in the F150.
The current dilemma is I have a friend that works at a local Ford dealership that bought the first F150 Ecoboost that came out in 2011. We discussed when he ordered it and he basically ordered just as I would have if ordering my own. Truck is a F150 Lariat 4WD Crew Cab with 3.5 Ecoboost with 3.73 rear end. Truck has around 50,000 miles mostly just hwy miles. Think he has pulled a 8000 lbs bumper pull camper 200-300 miles a few times. He is ordering an identical 2015 F150 and will be selling this one. I have enjoyed my current truck and it seems to manage to do all I need it to do. Torn over whether to trade my current truck on this one and stay with the F150 or is there too much risk in the first year Ecoboost long term. Have even considered purchasing an older 3/4 ton for towing, but just don't tow enough to justify adding a second vehicle for three or four trips a year less than 30 miles one way. Gut feeling is to hold out one more year and give the Ecoboost another look then. For what I do, the F150 Ecoboost seems to be a good fit. There would be about 5% of the time a 3/4 ton would be preferred.
   / F250 6.2 V8 vs F150 Ecoboost #110
If the price is right and you friend takes care of his stuff get it.
Chris
2012 Ford F550 Service Truck (A52377)
2012 Ford F550...
Toro Mower (A50324)
Toro Mower (A50324)
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
BUSH HOG 1815R1 BATWING MOWER (A51247)
BUSH HOG 1815R1...
SLIDE MASTER ALUMINUM SLIDES (A54757)
SLIDE MASTER...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
