F250 6.2 V8 vs F150 Ecoboost
   / F250 6.2 V8 vs F150 Ecoboost #121
Personally, I don't believe nuances in gears are as big a deal as they used to be...3:08 vs 373 sure but, 3:42 vs 3:73 not so much in my experience. 3:73 is certainly better but not as much as it used to be.
A 6 speed trans will allows truck with a higher axle ratio to still perform good.
Go for it. My Fathers and Uncles Ecoboost trucks both have 3.55 gears and mine has 3.73 gears. I really can't feel the difference. None of us 3 Ecoboost owners have had any issues. Chris
I hear the same comments from others, but get a little hung up on the numbers on the tow chart. Looks like a significant increase by moving from 3.55 to 3.73. This will very likely be a truck I would keep 10 years and don't want to have regrets. My gut feeling is the 6 speed with 3.55 will outperform my 4 speed with 3.73 I have now...not to mention the engine difference.
Agreed, my point exactly.
I tend to agree...but...why is Ford showing a 1600 lb. increase with the 3.73 over 3.55? I don't tow daily and could very easily get by with either. I will likely keep a truck ten years or so and want to get what works as best for my needs as I can. Who knows...down the road we could end up with a camper to tow.
   / F250 6.2 V8 vs F150 Ecoboost #125
I hear the same comments from others, but get a little hung up on the numbers on the tow chart. Looks like a significant increase by moving from 3.55 to 3.73. This will very likely be a truck I would keep 10 years and don't want to have regrets. My gut feeling is the 6 speed with 3.55 will outperform my 4 speed with 3.73 I have now...not to mention the engine difference. <img src="http://www.tractorbynet.com/forums/files/trailers-transportation/413566-f250-6-2-v8-vs-image-858884852-jpg"/>
I don't get it. Your window sticker says 7200, but I don't see that number on the towing chart.
   / F250 6.2 V8 vs F150 Ecoboost #126
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=413566"/>
I will say I have never towed with the 3.55 gears, only mine with 3.73 gears, and it's a beast.
Go with your gut. Mine is usually right. Have the dealer find you a 3.73 truck. Me and my friends travel to get what we want. A one way airline tickets a a day or two drive home in your new rig is a small price to pay to get what you want and have to live with for the next 10 years.
Chris
   / F250 6.2 V8 vs F150 Ecoboost #127
7200# is the GVWR not tow rating. Not even close to the same thing.
Simply put the GVWR is the maximum weight that can be on the trucks tires. Let's say the truck weighs 5200 pounds, that would leave 2000 pounds of payload. Payload includes passengers, cargo, trailer tongue weight, ect.
Tow ratings are obtained by subtracting the truck empty weight from the GCWR. For arguments sake let's say the F150 GCWR is 15200 pounds. Once you subtract the truck empty weight this would leave 10,000 pounds for tow rating.
Chris
   / F250 6.2 V8 vs F150 Ecoboost #128
I have kept holding out, but feel now may be best time to make s change. The guy that has the 2011 has postponed moving to the 2015 until prices come down and I have found that they are running around $9500 off on 2014 XLT's with the 302A packages. Was looking for a Ecoboost, 4wd, Supercrew with Max Tow and 3.73 axle ratio. These are proving to be hard to find. I had convinced myself to move to the cloth seats from the current leather. Was wanting 40/20/40 seats versus buckets like have now. Rest of the family strongly encouraging to stay with leather. Found this truck on local lot with XLT, leather and few upgrades like HID lights and 20" wheels, all that I like. Been reading and talking more on the Ecoboost too about the moisture/condensation/misfire issue. Seems to be a fairly common issue. Overall seems a 50/50 split on Ecoboost versus 5.0 preferred. I will trailer my 5303, 4wd, with FEL with either 8' 3pt disc or MX6 cutter on a 22' bumper pull 3-4 times a year for approximately 30 miles round trip.
Looks like with a trade in I can get in a brand new truck for what I got in my current truck used with 45,000 miles almost 8 years ago with same features. Any reason to be concerned with the 3.55 axle or Ecoboost? Will be daily driver approximately 300 miles per week. All opinions and feedback appreciated!
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=413486"/>
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=413487"/>
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=413488"/>
I have a 2011 with the max tow package and 3.73 rear. My friend has had two with the 3.55 rear and our mileage is identical because we don't spend much time on the interstate. I enjoy the huge mickey mouse mirrors that cone with the max tow package over the stock mirrors even without towing.
The towing advantage with the 3.73 over higher ratios is the torque stress on the gears happens in the rear end rather than within the transmission. The gears in the rear end are better supported and larger than those in the transmission so you are having less wear due to extreme pressures needed in a smaller gear pack. Your driveshaft will be spinning a little faster but with less torque. These driveshafts on modern trucks are huge to take the stress of these modern engines as it is. One other area helped by a lower rear end would be the u-joints being loaded less.
From what you can tell, is the mirror change the only/major difference with the Max Tow? I have a window sticker from a Max Tow and it seems to have an increased GVWR too.
Two questions:
#1) How many miles do you have on your 2011?
#2) If replacing today...Ecoboost or something different?
   / F250 6.2 V8 vs F150 Ecoboost #130
The picture shows a 5.5 long box but the sticker says 36 gallon fuel tank. I thought you had to have the 6.5 box to get the larger fuel tank.
2014 COMPTANK  ACID TRANSPORT TRAILER (A55745)
2014 COMPTANK...
Year: 2015 Make: Ford Model: F-350 Vehicle Type: Pickup Truck Mileage: 66,687 Plate: Body Type: 2 (A53422)
Year: 2015 Make...
2019 Chevrolet Silverado1500 LD Crew Cab Pickup Truck (A55852)
2019 Chevrolet...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
GRINDER (A55745)
GRINDER (A55745)
2016 Dodge Charger SRT Hellcat Sedan (A53424)
2016 Dodge Charger...
