Used v2800 Fransguard
   / Used v2800 Fransguard #21
Yes, it should pull the tractor but you must pull real hard in the rope. Often you must use your full body weigh on the rope.
   / Used v2800 Fransguard #22
Can you pull out the wire when the PTO is engaged?
The parking lot was so icy I could just about stand , so no I did not really pull hard like you said.
I did not try to pull the cable out with the pto engaged , due to the fact that it felt like if I'd unhooked the cable from the pole it would have just pulled the cable in .
   / Used v2800 Fransguard #24
It may just need to be used so the clutch releases properly.
Some people are over lubricate the drive chain and oil gets to the clutch so it sticks and slips under load.
2005 MACK CHN613 WINCH TRUCK (INOPERABLE) (A50854)
2005 MACK CHN613...
2022 Ford F-550 XL Crew Cab Forestry Chipper Truck (A49461)
2022 Ford F-550 XL...
2019 BIG TEX GOOSENECK  TRI AXLE 34FT 2 CAR HAULER (A51222)
2019 BIG TEX...
Toyota 6FGU25 Forklift  5,000 lb Capacity (A51039)
Toyota 6FGU25...
LOT LOCATIONS (A51219)
MCELROY COOL PACK 20 (A50854)
MCELROY COOL PACK...
