Used v2800 Fransguard
   / Used v2800 Fransguard #21
Yes, it should pull the tractor but you must pull real hard in the rope. Often you must use your full body weigh on the rope.
   / Used v2800 Fransguard #22
Can you pull out the wire when the PTO is engaged?
The parking lot was so icy I could just about stand , so no I did not really pull hard like you said.
I did not try to pull the cable out with the pto engaged , due to the fact that it felt like if I'd unhooked the cable from the pole it would have just pulled the cable in .
   / Used v2800 Fransguard #24
It may just need to be used so the clutch releases properly.
Some people are over lubricate the drive chain and oil gets to the clutch so it sticks and slips under load.
2018 Toro Groundsmaster 7200 72in Zero Turn Mower (A48082)
2018 Toro...
2007 CHEVROLET SILVERADO 4X4  DUALLY TRUCK (A51222)
2007 CHEVROLET...
2013 FELLING  SKINNYNECK TA LOWBOY (A50854)
2013 FELLING...
2006 CHEVROLET EXPRESS SERVICE VAN (A51219)
2006 CHEVROLET...
Blue-Jet Liquid Fertilizer Applicator (A51039)
Blue-Jet Liquid...
S Houle WD-10B Pull-Behind Hydraulic Turf Aerator Tractor Attachment (A49461)
S Houle WD-10B...
