My new PJ 14K trailer
   / My new PJ 14K trailer #21
Nice unit! I got the same one only with a 3' dove. I hate skinny trailers and working around fenders. Enjoy! are your running a weight distributing hitch at all?
   / My new PJ 14K trailer #22
have you scaled it yet? i curious what your empty weight with the sides is.
Thanks! Currently Im just using a pintle/ball hitch and it works well. I haven't had a problem with balancing my loads yet. Im going to be hauling a mini excavator in April and that will probably help me decide whether I need one or not.
I weighed it with all of my straps, chains, binders, and sides and it was 4005 lbs.
   / My new PJ 14K trailer #24
You said you plan to haul 3 cords of wood. A cord of fresh cut wood will range from 5,000 to 5,600 lbs. If you have 2 - 7,000 lb axles and take in the weight of the trailer it's self, 2 cords of wood would be pushing the trailer's maximum capacity.
   / My new PJ 14K trailer #25
I think only osage orange or some species of oak weigh that much when green. Most are in the 4-4500lb range. Still too heavy to haul 3 cord though.
I only haul dry split wood from my woodlot to my home. Also Red oak, which I burn, is around 3500lbs a cord.
   / My new PJ 14K trailer #27
That sure is a great looking trailer! How were the slide in ramps for the mini ex. I want the slide In ramps, but was unsure how they would handle larger loads, such as my scissor lift. I will probably get the 16 or 18' as we have a 20' deck over down the road on the farm.
I had no problems with the ramps but, I used my bucket to help get on the trailer. I usually back up to a bank near my house if Im worried about loading something. Again If I could do it all over Id get one with monster ramps to have the best of both worlds ( flat deck when folded, and easier loading).
   / My new PJ 14K trailer #29
Sterff - Did you register your trailer with a lower load rating because your tow vehicle GVWR is over 12K?....Gary
No, I registered it at 9990, because in PA any trailer with a GVW rating higher than 10K requires a CDL.
2017 COTTRELL TRAILER (A55788)
2017 COTTRELL...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2021 CATERPILLAR 349 EXCAVATOR (A52707)
2021 CATERPILLAR...
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
2017 John Deere 8370RT Track Tractor (A53485)
2017 John Deere...
UNUSED FUTURE FT-CL100C HYD CLAMP GRABBER (A52706)
UNUSED FUTURE...
