Hay ring vs unrolling.
   / Hay ring vs unrolling. #31
Here the farmers will use both methods. Usually if they are feeding rolls of clover hay to dairy cows its in rings. Otherwise the field hay in rolls is unrolled like a jelly roll. Seems to be quite a bit of loss either way.
   / Hay ring vs unrolling. #32
What are you guys using to unroll that hay?
   / Hay ring vs unrolling. #34
If on relatively level ground after twine or netwrap removal if one determines direction hay was rolled and puts frt tire of tractor against the opposite direction of rolling the frt tire will unroll the bale as tractor is driven forward. I've only done this unrolling of bale with a 2 wheel drive not a 4 WD but I think a 4 WD will work the same way
   / Hay ring vs unrolling. #35
Jim,
On a four wheel drive you pull up with the front tire tight along the flat side of the bale and sort of turn into the bale as you go. With a slight down hill you can go pretty straight but on flat ground you end up with about a 30'-40' circle of hay.
   / Hay ring vs unrolling. #36
Jim,
Why 30'-40' circle? I've unrolled several bales on level ground that I had an OOPS with no netwrap applied by using frt wheel to unroll them relatively straight so I could re-bale with netwrap on them
   / Hay ring vs unrolling. #38
We are rolling out hay this year. I can definitely see the waste when we put out too much. But if we put out just enough then they eat more than they mess up. We just use the tractor and the rolling hills to unroll it. The reseeding is an added plus since we are working on restoring and old rock quarry.
   / Hay ring vs unrolling. #39
If I understand the way you are unrolling yours there is a difference in the way you and I are unrolling the hay.
   / Hay ring vs unrolling. #40
hay ring vs unrolling
what I use is a device that attaches to my 3 point hitch, it has one long spike about 3 feet long that you spear the bale near the center ,it has 3 shorter spikes about a foot long that also penetrate the bale , it has a hydraulic pump and 2 hoses to attach to one of your remotes. So you just back ,spear the bale , take it to the cows , pull your remote lever and the bale will spin. The one I have I can spin a bale off in about 15 seconds. The one I have has this information written on it. A. S. I. Kimball, Ne 800-445-1001 . also has "RW Spin Off" written on it. It works great. You can spin off little piles of hay or just put out a windrow if you wanna. I highly recommend if you want to conserve hay.
2021 Deere 333G (A53317)
2021 Deere 333G...
2015 JOHN DEERE 1050K WH CRAWLER DOZER (A52707)
2015 JOHN DEERE...
Towable arrow board (A55973)
Towable arrow...
2018 KAUFMAN 44 FT CAR CARRIER TRAILER (A57880)
2018 KAUFMAN 44 FT...
2011 Ford Explorer Limited AWD SUV (A56859)
2011 Ford Explorer...
LMC 2-Row Planter BYJ-2F  Stainless Steel Fertilizer Boxes, Ground-Driven (A55315)
LMC 2-Row Planter...
