Ford 450 vs Ram 3500
   / Ford 450 vs Ram 3500 #61
The early 6.7 engines used in the C&C trucks had turbo problems and also had a problem with dropping valves. The engines used in the C&C trucks use a different turbo than what's used in the pickups. I've talked with the service manager of the dealership I use and he says they're not seeing many problems now. A lot of problems with the emission systems used in service trucks come from long periods of idling. Plugs up the DPF if a regeneration is not forced. A lot of utility companies are switching back to gas engines just because of DPF problems. You can still get a V10 in Ford C&C trucks.
   / Ford 450 vs Ram 3500 #62
Jess- Regarding your comment on the V-10, I am told Ford started putting the V-10 in Class 6 650's for the very reasonb you mentioned-the regen issue and the utilities/tree service companies were having a lot of issues because of their high PTO hours. Ford's sales numbers in class 6 and 7 are way up and I'm sure the V-10 option is a very big factor. To say nothing of the first cost savings over the standard Cummins in those trucks. If you don't run the snnual miles and if you don't need that diesel torque, the V-10 makes a lot of economic sense.
In the meantime, there is an Altec branch a few miles from me and I periodically swing through their yard. Ford 550's predominate the chassis pool in that 19,000 pd class and most of them are Power Strokes. It does appear Verizon is sticking with gas though.
As for class 7 trucks, Freightliner rules
   / Ford 450 vs Ram 3500 #63
Wow! With an experience factor you are having, its a wonder Ford is still in business. Just what is the application these trucks of yours are in?
What is even more amazing, after the first nine blew their motors at under 50k, you bought four more?
It wasnt my decision!!. I simply drive one of them. We have Cobalt service beds on the trucks with pto driven cranes, compressors, and out riggers.
The engine failures have slowed down except for the 12 model that spun 2 main bearings while at the dealership for a transmission overhaul! Turbo failures are still rampant during the summer time months, random derates/shutdowns due to the aftertreatment system.
We are in somewhat of a corner for service trucks, GM does not offer anything in the 1 1/4- 1 1/2 ton market, and Ram has the "Wrong C" on the fender. So we are stuck with Ford. Recently, our fleet manager has purchased a couple of Internationals to test....
Our trucks Idle for 10-12 hours straight sometimes, thats really not an issue, as long as you drive it about 30-45 minutes before shutting it down for the day, it hasnt been an issue. Our aftertreatment issues have been DEF pumps failing, random exhaust sensors, and of course the turbos failing saturating the exhaust filters with engine oil.
   / Ford 450 vs Ram 3500 #64
Thanks for the heads up, we have had nothing but problems out of the Kodiac series so GM is out. The Dodge is still a option but not a very good one. We could find a few more low mile 450's but we were looking at new units. The pto's have to be capable of 30-40hp also. So that limits our choices too. Gas engines have a hard time with pto loads that high. Sooo we have been looking at putting deck engines just to run the hydraulics. Looks like the IH or Freightliners are the way to go. CJ
   / Ford 450 vs Ram 3500 #65
yeah, Cobalt actually puts a little "pony motor" in the bed on the gas engine equipped trucks that powers the hydraulics.
2013 John Deere 35D Mini Excavator (A55973)
2013 John Deere...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
2015 Ford Fusion Sedan (A55853)
2015 Ford Fusion...
2006 Hyundai Sonata Sedan (A55853)
2006 Hyundai...
2014 Ag Spray Schaben Sidedresser (A57024)
2014 Ag Spray...
