JESSE1
The early 6.7 engines used in the C&C trucks had turbo problems and also had a problem with dropping valves. The engines used in the C&C trucks use a different turbo than what's used in the pickups. I've talked with the service manager of the dealership I use and he says they're not seeing many problems now. A lot of problems with the emission systems used in service trucks come from long periods of idling. Plugs up the DPF if a regeneration is not forced. A lot of utility companies are switching back to gas engines just because of DPF problems. You can still get a V10 in Ford C&C trucks.
