block heater on sc 2400??
   / block heater on sc 2400??
You can also try this site.... Wolverine Engine Heaters
they sell, and i have purchased 3 of them, a glue on heater. they are super easy to install and dont have to drain anything.
And boy do they work great
I put on a 125 watt heater on the oil pan (needs a flat spot, no ridges), a 250 watt heater on the transmission/HST unit and another 250 watt heater on my 3 point reat hydraulic tank that supplies the snow blower.
I set mine to operate on a wall timer for a few hours before i need the tractor, and only use them if the temp is below 20F.
Without them everything growls and protests starting up (like i do climbing out of my warm bed) , but with them everything starts nice and smoothly....major difference.
Thanks for the website. Maybe I will change my plans and get one of these for the oil pan and transmission. These look like the perfect product for me.
   / block heater on sc 2400?? #12
I personally didnt want to break into the freeze plugs or heater hose so i thought this was the least invasive approach to the issue.
I have a similar heater on my internet dish for 5 years...works great.
   / block heater on sc 2400?? #13
Yes, they are just sheet metal stamped in a cup shape and pressed into the recesses. I usually drive a screwdriver through the center and then pry them out for removal.
Bob B.
Well I ordered a oil pan heater today from shop.Wolverineheater.com . After I install it I will report back my experience and the effectiveness. I got a 125 watt unit. I hope all goes well.
   / block heater on sc 2400?? #15
Well I ordered a oil pan heater today from Wolverineheater.com . After I install it I will report back my experience and the effectiveness. I got a 125 watt unit. I hope all goes well.
I put the 125 watt on my oil pan... took like 30 seconds to attach and 30 seconds to silicon the edge. Read the instructions though. when i pre-heated mine, i went for 10 seconds instead of the 3 sec that they recommend...nearly burnt my hand. That thing sure gets hot.
It was 18F this morning, and the preheater had been on for 2 hours about 1 hour PRIOR to my starting tractor..... the engine just purred....no grunting at all like it does when i tried to start it in 30F weather without the heater.
Well I have had the new heater hooked up about 2 weeks now. It used to really struggle at about 30 degrees. The coldest it hass been so far is about 20 degrees and with it plugged in for about 4 hours the tractor started right up no problems at all. It only took me about 5 minutes to install and I have it plugged in to a remote controlled plug so my wife can just push a button to turn it on while Im at work and Im good to go when I get home. So far so good, great product.
   / block heater on sc 2400?? #17
Did u ever put your block heater on? if so how does it work? I live in frederick md, tractor is hard to start..read your forum and see that u have a similar tractor as I do (i have the SC2400) ...did u get the heater for your freeze plug? Called the dealer and they can get it for $50. who is it made by? how easy to put on? u said 5min. Dealer said it would cost $90 to put on but for 5 min I'll do it myself.
I got a "wolverine heater" it glues to the bottom of the oil pan. It worked good for 2 years on my sc2400. Now I have a sx3100 and got the same type of heater and it works good. They need to run longer than a freeze plug heater but are much simpler to install. I had one quit working on my current tractor and called them up and they sent me a new one out no questions asked.
Sent from my iPhone using TractorByNet
   / block heater on sc 2400?? #19
Anyone have a link for the freeze plug heater for the sc2400?
My dealer no longer sells Yanmar, and the newer dealer isn't very helpful.
   / block heater on sc 2400?? #20
I like the idea of a wolverine pad on the hydro
Brent 420 Grain Cart (A55301)
Brent 420 Grain...
2006 Toyota Tundra 4X4 Pickup Truck (A55788)
2006 Toyota Tundra...
Club Car Carryall 1500 Diesel Utility Cart (A55787)
Club Car Carryall...
2006 Reelmaster Toro 3100D Mower (A50324)
2006 Reelmaster...
2015 UTILITY VS2RS 53FT REEFER TRAILER (A54607)
2015 UTILITY VS2RS...
2016 TRAILSTAR 40FT DUMP TRAILER (A54607)
2016 TRAILSTAR...
