Little advise needed - X700 series
   / Little advise needed - X700 series #1
ferguson41
Just got finished building a house last fall. Our old house was on property in town and I could cut everything with my push mower in about an hour and a half so I never purchased a rider. Our new property sits on about 1.5 acres with the back yard, about .75 acres, that is hillside. There is a lot of it that is sloped at about 25 degrees. I just wanted to get someone's thoughts on how a x738 or x758 would handle it. I borrowed my father in laws Husqvarna and took a serious ride down the hill, not fun. This is why I am looking for a 4x4. I cut the grass this past fall with my Polaris and pull behind mower. It does ok, but is hard on the grass. I also looked at the Kubotas, just because they are a bit cheaper, but after reading on this forum there seems to be some issues with the GR series. Thoughts, comments are appreciated.
   / Little advise needed - X700 series #2
I have a 748, it is a billy goat . Great machine
   / Little advise needed - X700 series #3
While the GR had a bad rollout, the new model is much better. The tight turning radius plus 4x4 is pretty awesome.
Sent from my iPad using TractorByNet
   / Little advise needed - X700 series #4
The X748 and X758 machines will go places you never thought possible. I have seen some youtube videos of guys mowing some extremely steep angles with absolutely no stability issues.
   / Little advise needed - X700 series #5
You might want to try a Ventrac if the JD does not work for you.
   / Little advise needed - X700 series #6
My X748 is an excellent choice for me. Great comfort mowing and snow blading.
   / Little advise needed - X700 series #8
I bought a Ventrac after several mishaps trying to cut my slopes with a zero turn. I don't have the patience to cut them up and downhill. I have a Ventrac 4000 series with double wheels and it is rated for side-hilling a 30 degree slope. It would be overkill for the OP's property size. Mine has an 84" contour deck. I also have a 60" rough cut deck, a power rake, a trencher, a stump grinder, a seed broadcaster, and a front scoop. The machine is incredibly flexible but not exactly a "value" proposition for limited use. I work mine quite a bit on a 40 acre property and a 7 acre property.
   / Little advise needed - X700 series #10
A 25 degree slope (using easy mental math) is one that rises 1 FT for each 2 FT of travel. I have some areas that would be equal to that, probably a bit more steep. I usually mow there (drive up - back down) with the 3320. On taking delivery of X739 last fall, I did the drive up / back down test in the steepest portion. The x739 has HDAP tires - no fill - no weights
I would not hesitate to say 4WD 738/758 will handle up / down on a 25 degree slope with NO problem. Now, if you are planning on driving sideways, I can't offer a specific response. The slope varies where I cut, so some portions can be done sideways with either the 3320 or Craftsman, but I haven't taken measurements to determine how many degrees at the point where i decide sideways is too far.
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50774)
ALL ITEMS NOT...
2013 UTILITY VS2DX 53FT DRY VAN TRAILER (A51222)
2013 UTILITY VS2DX...
(INOPERABLE) CAT D4D (A50854)
(INOPERABLE) CAT...
Deere 9970 Cotton Picker (A51039)
Deere 9970 Cotton...
KUBOTA M7040 TRACTOR (A51406)
KUBOTA M7040...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
