EricW
- Joined
- Nov 26, 2013
- Messages
- 61
- Location
- Little Flock, AR
- Tractor
- Massey Ferguson GC 2300, 1954 Case SC, 1952 Farmall Cub, 1946 John Deere A, Massey Ferguson 130
Hi Everyone,
This is my first time posting a question here. I just bought a house in December and with the house I also bought a used GC2300 that I think is a 2003. I am having a problem trying to get it started. Let me start out by giving everyone the full story. When I first moved in the temps were very cold for Arkansas. The GC's battery was shot and I was able to jump it off of my ATV battery. That lasted 1 run and then the tractor sat in my pole barn for a few weeks. I tried starting it again when the temps warmed up a bit and the only way to get it running by jumping it. This time with a larger battery than the ATV battery. After that I cannot get the tractor started no matter what, so today I went out and bought a brand new battery and it will crank and crank but it doesn't even give a hint that it wants to start. So, tomorrow I have a new fuel filter that should be here that I am going to try. I'm crossing my fingers that it isn't getting diesel. Here is what I have noticed.
1. When cranking or turning over it generates a lot of black smoke. When I did happen to have it running it didn't smoke nearly that much.
2. I read somewhere to look for a broken ground. I have found one coming off the battery and possibly one coming off the left side of the engine. Both look good. If anyone has any pictures of what I should be looking for that would be awesome.
3. When it was running, it ran perfect. And it would restart if you turned it off and tried starting it again.
If anyone has any tips on how to get this thing running that would be great. And it does have a FEL which is lowered to the ground. Is there a way to raise this if I can't get the tractor running? The 2300 is blocking my Rzr from getting out of the barn so I would like to move the 2300. I'm sure I can drag it backwards (assuming the hydro is in neutral and doesn't bind) with an ATV. But pushing it back forward with the FEL is going to be tough.
After spending what seems like a never ending sum of money on this move I can't justify bringing the GC into the shop just yet so if we can figure this one out, then I can start playing around the yard the my (new to me) Massy
Thanks in advance and I look forward to hearing your responses.
Eric
Eric
