Hello from Norway! MF135 found in bushes!
   / Hello from Norway! MF135 found in bushes!
Hi TomSeller (and everyone else).
The hydraulic rams for the front loader are powered via a diverter valve from the main pump on mine. Which tractor have you got?
Grayson
   / Hello from Norway! MF135 found in bushes! #12
Grayson
I have the MF245, yours is different than move and you are powered off the internal pump. Were your 3 point arms lifting?
   / Hello from Norway! MF135 found in bushes! #13
Hi,
I guess i should post this in MF classic section too?
Anyway - problem no hydraulics!
I've changed the oil and filter plus diesel flush with no effect.
Had a look through dip stick cover and all looked ok, lever operation and outlet pipe connected. Looked ok.
So i've taken the hydraulic lift cover off, drained all the oil again and taken off the pressure control valve (as in the picture) as i removed it, the cap came off and spring fell into 10 pieces. Also as i removed the pipe to the diaphram it appeared to be full of water (clear fluid).
So i have taken the whole thing down to the local garage for them to sort it (i panicked).
I the meantime i am going to clean all the sump and components in there. Theres a good 2cm of sand etc covering the bottom! Really dirty.
Is there any other things i should be checking? Is this the cause of no hydraulics have i broke it more?
Spring no. 3 broke!
That looks like the hydraulic pressure relief valve. With the spring broken, it likely is just circulating the oil at low pressure but cleaning up of the sump and other components, getting all the old oil and water out is mandatory. Likely if you took to a good shop they can fix it up for you.
   / Hello from Norway! MF135 found in bushes! #14
Welcome to TractorByNet!
I moved your thread to the Massey Ferguson Owning & Operating forum. :)
   / Hello from Norway! MF135 found in bushes! #16
Hyggelig å se at det er flere Normenn her:thumbsup:
   / Hello from Norway! MF135 found in bushes! #17
Wilkommen, Halsnings från New Hampshire!
   / Hello from Norway! MF135 found in bushes! #18
where in Norway are you from??? my wife was just over there...and she is Norweigan like to hear from you.
   / Hello from Norway! MF135 found in bushes! #19
What he said..... :D
Welcome to TBN. Word must be spreading in Norway. Seems to be a growing list of members. :)
   / Hello from Norway! MF135 found in bushes! #20
I told him it was Nice to see more Norwegian on TBN. I'm guessing that Norwegian does not make much sense to you who grew up with the English language and google translator has a unique ability to mess up the translation from Norwegian to English on an epic level at times :laughing:
2022 Polaris Ranger 900XP 4x4 Utility Cart (A55853)
2022 Polaris...
2009 Honda Pilot AWD SUV (A56859)
2009 Honda Pilot...
2012 Chevrolet Silverado 2500HD Enclosed Service Truck (A55973)
2012 Chevrolet...
2007 Chevrolet Silverado 1500 Single Cab Pickup Truck (A55973)
2007 Chevrolet...
2007 Yamaha Rhino 660 (A55315)
2007 Yamaha Rhino...
Zero Turn Mower (A55853)
Zero Turn Mower...
