Oil bath hubs
   / Oil bath hubs #11
RubenK. Hope you have a safe and trouble free haul. lt190b
   / Oil bath hubs #12
wonder if the 0 or 00 type pourable grease would be the best of both worlds. I know my tiller wont keep 140 weight in it, but with the 00 does it not leak a drop.
   / Oil bath hubs #13
That's why I like this place. Always learn something. Never heard of 00 type pourable grease.
   / Oil bath hubs #14
Its somewhere between ketchup and mayo on the consistency scale.
   / Oil bath hubs #15
See now, I can understand that. Not some technical numerical ISO or whatever description that I'd never understand!!! Thanks!! I think I need some of that onhand. :)
   / Oil bath hubs #17
The oil bath hubs on my pj trailers take motor oil in them . They leak all the time . I run Lucas Hub oil . I over fill I feel better known'n there extra oil .
Sent from my iPhone 5 using TractorByNet
   / Oil bath hubs #18
Has anyone thought about using bentonite grease as a replacement for the oil?
   / Oil bath hubs #19
What's it's primary use and consistancy??
   / Oil bath hubs #20
The only place I've used it so far is in the rear transaxles on a garden tractor but I'm thinking of using it when I repack my triaxle 12 ton equipment trailer. It's designed to work much better than other types of grease under high pressure in bearings and places where metal on metal wear occurs. I think they call it poundout. The bentonite (clay) keeps the grease from running out and it's very water resistant. It tends to be expensive and it doesn't mix well with other oils or greases (so you need to clean everything well). I have a tube of "persist bentonite grease that states it's ideal for heavy load trailer bearings.
6 Yard Commercial Dumpster (A51692)
6 Yard Commercial...
2008 Chevrolet Silverado 2500HD Ext. Cab Pickup Truck (A52377)
2008 Chevrolet...
UNUSED 3.5X2X2M GREEHOUSE (A54757)
UNUSED 3.5X2X2M...
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATES (A54757)
UNUSED LANDHONOR...
2006 FREIGHTLINER CL120 DAY CAB (A53426)
2006 FREIGHTLINER...
2014 CATERPILLAR 305E CR EXCAVATOR (A52706)
2014 CATERPILLAR...
