already switched to compact flour and energy efficient appliances ... its the electric baseboards ... finally got nat gas on the street.. going to connect this summer ( if I'm not broke from the bills ).
I've got two woodstoves and a mid efficiency oil furnace that is 20 years old and still working at 86% as of last year when it was serviced and it burns diesel. It gets serviced every year whether it needs it or not.
An elderly family member that lives in a ~1400sqft house next door has been using an oil furnace, to the tune of about $3,000 per heating season. The heating season is not real long here in southeast VA, so that works out to say $700 a month during the heating season. This year she asked me what I thought about using the old baseboard heaters instead of the oil furnace. I checked em and they worked, so we decided to leave the furnace off (and disable automatic oil delivery) and see what the baseboard heaters could do. Her monthly electric bills, so far, have been about $150-$200 more than last years bill, so she's saving in the neighborhood of $500/month by using electric baseboard heat instead of the oil furnace. The oil furnace did get serviced annually. Only thing I can figure is that
a) oil has gotten real expensive, over $4 per gallon (I can get diesel cheaper, and that includes the road tax). electricity is about $.11/kwh
b) Right before heating season started, I noticed a leak in her ductwork in the attic, but it doesn't seem to cause big issues for the A/C. Probably been leaking for a long time.
c) each rooms baseboard heat is controlled by its own thermostat and she tends to turn up the room she's in at the time.
d) every bit of produced heat goes directly into the living area. No heating up the garage where the furnace is or heat loss due to ductwork running outside of living area.
This all surprised me as I had always heard oil was the way to go, unless you could use a heat pump.
Keith
