Air forced turbo heater/ salamander
/ Air forced turbo heater/ salamander #41
mine states on the unit that it will burn #1 diesel, kerosene or jet fuel. The instructions stated that you can burn diesel in it. Ive been burning nothing but diesel for 4 years now. never had any issues. I use it alot, and store it with fuel in it. As i say, ive never had any issues.
mind you, i only use winter blend diesel in these as there only run in the winter. up here, winter blend is supposed to be a mix of kerosene and diesel.
Well I change the fuel to kerosene..... NO SMELL!! someone put dyed fuel oil or off road diesel fuel for sure! I'm sure diesel no1 may be ok but the smell is gone. I added scented additive :)
/ Air forced turbo heater/ salamander #43
they do tend to smell a bit...but since i use it to shed off snow in t outbuildings..one being a barn. whats a little more stink.
In my shop i only use it to take the edge off cold. I mostly use 125,000 btu propane shop furnace when working in there. Ill probibly add a pellet stove in the near future
It's a new heater now the smell and getting very sick are all gone. It smells like hot air now
/ Air forced turbo heater/ salamander #45
when I use mine I be sure to locate it close by a window, leaving the window open about 1" as I stated this one is thermostat controlled and when it cuts off and back on again at first startup it can puff a good bit of smoke into a room, and that stuff can choke ya! and is also another reason that I don't use it that often,
Mine auto starts, not sure if they all do, but this is a great add-on for one of the heaters Amazon.com - Reddy Heater Thermostat for Kerosene Heaters #HA1210 - Thermastat For Portable Forced Air Kerosene Heater I have one around somewhere...
My dad and I have used plug in thermostats for different reasons but that one looks very high quality.
Last night while using the salamander I only ran it five minutes before getting really sick. I used my suction gun to remove as much of the "red" dyed fuel as I could, added 1/4 to half a gallon of kerosene and removed all the fuel I could again and added two gallons of fresh kerosene. All I could smell was hot air!! Someone really did pump summer diesel or no 2 fuel oil in that think. It felt like I had a Diesel engine running in the garage with the door closed. Once the fuel was replaced it was just hot air and acted just like my friends old Remington kero salamander only his is double the size at 115,000 btu.
Even in an emergency I would have trouble adding straight diesel to that thing!
/ Air forced turbo heater/ salamander #48
Mine actually has a bit LESS smell when using diesel vs kero. It's a Mr. Heater 40,000 btu IIRC. I use plain old #2 off-road diesel and it works great and only a slight smell. Still, I wouldn't run it for hours in an enclosed space!
- Jay
/ Air forced turbo heater/ salamander #49
how can someone named diesel lover hate diesel/....haha
/ Air forced turbo heater/ salamander #50
i have used kerosene in these over the years and i really dont notice any difference in stink. they both stink.
thats why i wouldn't use it for anything except quickly taking the chill off the shop till the propane heater takes over.
as far as the stink in the horse barn...why would notice
/ Air forced turbo heater/ salamander #51
I have a 220000 btu one
and I use diesel in it
the trick that I learned is to roll it toward a door before firing it up and point it outside for a few min till the afterburner thing gets orange
once it's there then heat the building with hardly any fumes
when turning it off I take it outside also
never had a problem with anyone feeling sick
It might have been because there is transmission fluid, red home heating oil, or off road diesel in there. It smelled like and felt like I started my diesel Massey ferguson in the garage and left it running with the door shut!
When I sucked out all the fuel, mixed the small amount in the bottom of the tank with kero, and sucked the tank dry again it runs differently and all I smell is hot air and heat. No diesel exhaust smell.
I'm so happy that's all it was! I bought this used for 85$. To have to flush out the fuel and replace only costed 10$ worth of fuel. I feel like I can burn the mystery dyed fuel in my Massey ferguson diesel, any off road engine, or of course any older engine as HHO burns good in older Diesel engines.
I think if I added 20% diesel no 2 to 80% kerosene it would probably burn ok. It is nearly impossible to buy no 1 diesel here. Some people I know here in Indiana mix 10% kero to the "winter blend" diesel at the pump in their farm tractors etc when it drops to zero or below 0. You can't trust the stuff at the pumps here.
Thanks guys
This seen here is the same exact heater as mine!! Some great information here on the heater itself!!
http://youtu.be/ve0nzByP6SU
Replacing spark plug and coil, adjusting the pressure back to 3.4 psi, and other great information seen here.
/ Air forced turbo heater/ salamander #54
Well, I got my heater working. The truth is, like so many arduous repair tasks, in the end, I never did figure out what was the matter.
Kerosene does NOT seem to go bad with age. But it's burning properities and characteristics when mixed with air continue to alude me.
I changed my hoses, but the ones my friend brought were the wrong size. Maybe these are POS metric or something.
I had gotten another unknown burner nozel in case mine was bad. I could not make it work. Maybe it was for a larger unit. Anyway, I was thinking, in case the kerosene in my heater was bad, I put the hose into a small soup can of Diesel. I could not make it work. Then, I used my old nozzel and found it did not work. It turned out to be plugged on the fuel side. I unplugged that in a hurry and reassembled the unit. It worked!!! I calibrated the pressure to 4.3 PSI and switched back to the kerosene supply. Still worked!
It seems that several aspects of these units successful operation is quite critical. Air/Fuel mixtures and air pump pressures are quite important it seems.
In the END, I can't really say what my problem was, I'm just glad after all that farting around that the thing works again without buying new parts. A year ago already, I almost bought a new nozzel on line.
This thing has no idea how close it came to becoming flattened! Again, and again, I had to just keep reminding myself, "how complicated can this be"?
Well, I got my heater working. The truth is, like so many arduous repair tasks, in the end, I never did figure out what was the matter. Kerosene does NOT seem to go bad with age. But it's burning properities and characteristics when mixed with air continue to alude me. I changed my hoses, but the ones my friend brought were the wrong size. Maybe these are POS metric or something. I had gotten another unknown burner nozel in case mine was bad. I could not make it work. Maybe it was for a larger unit. Anyway, I was thinking, in case the kerosene in my heater was bad, I put the hose into a small soup can of Diesel. I could not make it work. Then, I used my old nozzel and found it did not work. It turned out to be plugged on the fuel side. I unplugged that in a hurry and reassembled the unit. It worked!!! I calibrated the pressure to 4.3 PSI and switched back to the kerosene supply. Still worked! It seems that several aspects of these units successful operation is quite critical. Air/Fuel mixtures and air pump pressures are quite important it seems. In the END, I can't really say what my problem was, I'm just glad after all that farting around that the thing works again without buying new parts. A year ago already, I almost bought a new nozzel on line. This thing has no idea how close it came to becoming flattened! Again, and again, I had to just keep reminding myself, "how complicated can this be"?
glad you got it working!! It's just like a small engine. I don't blame you for getting upset with it. They can be stressful to fix when you need them the most. Nice job.
/ Air forced turbo heater/ salamander #56
I thought about this a little last night. I am guessing there was an obstruction in the nozzle. Not total, as I saw mist coming out, but I guess not enough to burn.
It's a very easy fix and not one I ever heard or saw mentioned when speaking of these heater repairs.
Just unscrew the large brass nozzle and blow both pieces out.
The thing that lead up to this whole hassle was the heater running for a few minutes, then sputtering and shutting off.
New/Unused Quick Attach Bale Spear (A57454)
New/Unused Quick...
2008 MACK CHU613 DAYCAB (INOPERABLE) (A58214)
2008 MACK CHU613...
1986 Military MEP 0006A 60kW Towable Diesel Generator (A59228)
1986 Military MEP...
44052 (A55852)
44052 (A55852)
2461 (A58376)
2461 (A58376)
2019 Chevrolet Silverado 6500HD 4x4 ETI ETC37IH 37FT Insulated Bucket Truck (A59230)
2019 Chevrolet...
