Poulan Chain saw 2013 Model 50cc Pro
   / Poulan Chain saw 2013 Model 50cc Pro #11
You may want to check the High and Low Setting on the Carb - I'm sure with it being a newer model chainsaw you will need the special adjustment screwdriver.
finally got time to watch..and will be ordering that fancy tool...why companies feel they can force into a high dollar repair shop by changing things to use tools we do not have already....I will never know
   / Poulan Chain saw 2013 Model 50cc Pro #13
I think you can thank our illustrious EPA for that. They know what's best for us .
   / Poulan Chain saw 2013 Model 50cc Pro #14
Kewl beans. This guy is so good at explaining things.
He's even got a channel for the French speaking Canadians in Quebec.
You can watch his other videos and learn a ton of stuff about fixing other machines around the home...
Snow Blowers
Chain Saws
or almost any 2 cycle equipment
Mowers of just about any type
Enjoy
   / Poulan Chain saw 2013 Model 50cc Pro #16
Lately, it seems that all small engine carbs have plastic "limiter" caps pressed or molded onto the jet adjustment screws (EPA-required, I guess, to prevent us clueless consumers from adjusting anything so that emissions might result!!). I have found that these can almost always be removed with either some side-cutters, or a dremel cutoff wheel very carefully applied so as to cut only the plastic. Underneath the plastic, there has invariably been an old-style adjustment slot cut into an old-style adjustment needle. I had one little echo chainsaw that refused to idle and only required backing the Lo speed needle out a few turns and then resetting at about 1 to 1-1/2 turns to clear it out. Of course, I had to remove the plastic limiter to do so.
Now, keep in mind that all of the above is purely theoretical and in my imagination only, as I would NEVER actually modify any gubmint agency mandated "safety" features!
- Jay
   / Poulan Chain saw 2013 Model 50cc Pro #17
To remove the limiter caps, you can thread a drywall screw into the cap and then pull it out. Normally they are designed to slide in/out when the screw is in a certain position. I've done this on two saws I bought recently that needed adjustment. No special tools required.
SKID STEER ATTACHMENT AUGER (A58214)
SKID STEER...
2014 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2014 UTILITY VS2RA...
UNUSED FUTURE LS43 43" HYD LOG SPLITTER (A58376)
UNUSED FUTURE LS43...
LOT: Clevis Hook, Snatch Block (A59076)
LOT: Clevis Hook...
New/Unused 20ft Bi-Parting Iron Gate (Elk Design) (A57454)
New/Unused 20ft...
New/Unused 20ft...
