Kubota HST Side-by-Side Pedal Modification
   / Kubota HST Side-by-Side Pedal Modification #81
JUst another thought here. Is the clutch on a Kubota an actual clutch or is it just a hydraulic dump. If you don't like the clutch on an hst can you not just remove the pedal? Or unhook the wires if it's just a hydraulic dump?
It is an actual clutch. Added mechanism for not benefit. It does make a mechanical break between the engine and the rest of the tractor which could be used as an emergency stop on the pto.:confused3:
   / Kubota HST Side-by-Side Pedal Modification #82
The main clutch is much larger and cheaper to replace than the pto clutch pack. Fantastic for starting large pto loads where other CUT's would not last long. Feathering the pto clutch pack not recommended, use the main clutch.
(APPROX. 20) 4' X...
iDrive TDS-2010H...
2013 Ford Explorer SUV (A59231)
2013 Ford Explorer...
Kubota RTV X1140 (A60462)
Kubota RTV X1140...
2015 FORD F-250 XL SUPER DUTY EXT CAB TRUCK (A59823)
2015 FORD F-250 XL...
2008 Ford F-350 4x4 Ext. Cab Knapheide Service Truck (A59230)
2008 Ford F-350...
